Electric Tach
Old Sep 8, 2002 | 09:37 AM
51dueller's Avatar
51dueller
Electric Tach
We have an old Tach that we used on our old John Deere combine. Would we be able to hook it to a '51 Flathead V-8. It has four wires white, green, red and black. Would someone tell me what each wire does and goes to.
Thanks
Nathan
Old Sep 9, 2002 | 09:54 PM
angus's Avatar
angus
Electric Tach
I'd guess they are for +12, ground, lamp, and points. If I'm right, and there is a lamp, you could use an ohmmeter to measure from the lamp contacts and identify two of those wires. There'd be some resistance from ground to the +12 and maybe points wires (and infinite resistance from the "lamp" wire (if the bulb isn't installed). Then try hooking the remaining two wires to +12V one at a time, and tap the other one rapidly to 12V and see which one makes the needle do something appropriate. I wouldn't want to hook the +12 wire to the points because the high voltage on the points might fry something in the tach.
Use at your own risk. Not responsible for damage to tachs or household pets. Void where prohibited. This is not legal advice.
Old Sep 9, 2002 | 11:25 PM
bcguys's Avatar
bcguys
Electric Tach
Here's a stab at 'er:
Red = + 12 volt
Black = neg grnd
White = illumination + 12 volt
Green = - side of coil (assuming points and neg ground!)
Good Luck!
Todd.
Old Sep 9, 2002 | 11:27 PM
bcguys's Avatar
bcguys
Electric Tach
If your vehicle is positive ground and the tach is from a negative ground application, it won't work! Should have mentioned this before....sorry.
Todd.
Old Sep 10, 2002 | 07:26 AM
mercuryblues's Avatar
mercuryblues
Electric Tach
also assuming 12 volts
Old Sep 10, 2002 | 08:26 AM
vwjer's Avatar
vwjer
Post Electric Tach
diamondrcattle
6.4L Power Stroke Diesel
17
Mar 7, 2014 08:21 AM
REXHOUND
Jan 14, 2014 10:16 PM
jonbass40
General Diesel Discussion
59
Oct 22, 2010 01:06 PM
80351
Maryland Chapter
17
Aug 30, 2008 07:04 PM
FordRuss
General Automotive Discussion
16
Apr 30, 2004 01:50 PM
