5.4 Makes a rattle when starting...
Old Oct 21, 2009 | 06:45 PM
jfaaborg's Avatar
jfaaborg
brought my 2003 Exp in to the dealer for the exact problem. They are going to replace the timing chain tensioner(s) under Warranty. The ESP premium warranty really paid off since I think my Exp was built on a Monday... had the rearend replaced twice, rear A/C blend doors, DVD player, radio, rearview mirror motors, and driver power window cluster replaced
Old Oct 21, 2009 | 06:54 PM
birchy's Avatar
birchy
If you do a search on this site you'll see lots of references to that rattle on the initial startup.. sounds like it's pretty common and no cause for concern.
Old Oct 25, 2009 | 08:12 PM
peter57's Avatar
peter57
could also be the cat. converter heatshield. I have a 98 with about those miles and it started making alittle rattle when cold but when it heated up and expanded, it would go away. I was able to re-tack weld it back in place and no more rattles
Old Oct 25, 2009 | 09:21 PM
jfaaborg's Avatar
jfaaborg
The timing chain tensioner replacement took are of the problem.
Old Oct 26, 2009 | 08:17 AM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
An air ride compressor test for noise? Start the Expedition with the passenger door (or any door) open. A compressor wont run with a door open, then you can isolate the noise as coming from the engine or the are compressor. Once all the doors are closed, the compressor should kick on and it has a different sound than engine rattle.
IslandBlueV10
Nov 11, 2017 12:56 AM
hellssorrow
1997 - 2003 F150
Sep 4, 2016 10:42 PM
02GrayPowerStroke
1997 - 2003 F150
Sep 11, 2015 05:19 PM
95moneypit
1983 - 2012 Ranger & B-Series
Feb 18, 2012 12:55 PM
Firefighter 1406
19
Mar 26, 2011 01:21 PM
