Bumpy brakes
Old Nov 7, 2006 | 11:35 AM
7.3PSD's Avatar
7.3PSD
Question Bumpy brakes
I've noticed that when I hit the brakes recently that my truck feels like its going over little bumps. It's more noticeable at higher speeds-35mph and up. Brake pedal is not soft and the brakes still slow the truck down, but its just the bumping feeling. Wondering if anyone has any places to start looking on this. Warped rotors maybe? Truck is a 2000 F350.
Thanks
Old Nov 7, 2006 | 11:56 AM
crack's Avatar
crack
I would think warped rotors.
Old Nov 7, 2006 | 02:47 PM
Pocket's Avatar
Pocket
Check caliper slide pins first, then rotors second.
Old Nov 7, 2006 | 03:57 PM
ponch37300's Avatar
ponch37300
I believe i remember reading something in guzzle's page about the slide pins needing to be replaced with better ones? Anyone know about that? I also have a vibratiion like warped rotors and was just planning on replacing them with powerslot cryoed and hawk pads but if i should replace the pins to while everthing is apart just to be sure to have smooth brakes? Thanks
Old Nov 7, 2006 | 04:07 PM
ryaneverk2's Avatar
ryaneverk2
Ponch, here's the page you're thinking of:
http://guzzle.rbmicro.com/cu.html
Old Nov 7, 2006 | 04:10 PM
AustinS's Avatar
AustinS
If you're going to spend the money on the rotors and pads, it would definitely make sense to do the new design pins.
Check your pads and see how they are wearing. I had a vibration problem from the front on my brakes and my right side outer pad was wearing at an angle. It is also a common problem for the caliper pistons to stick. I replaced the pins and pads on both sides and the right caliper.
Smooth as silk now.
Austin
Old Nov 7, 2006 | 07:53 PM
7.3PSD's Avatar
7.3PSD
Appreciate the help. I'll take a look and see what I find.
Old Nov 8, 2006 | 06:59 AM
ponch37300's Avatar
ponch37300
Where is the best place to get these new slide pins? Thanks
Old Nov 8, 2006 | 07:27 AM
ryaneverk2's Avatar
ryaneverk2
According to guzzle's page I linked to earlier... Ford, for about $20.
Old Nov 15, 2006 | 09:54 AM
2002f2507.3LPS's Avatar
2002f2507.3LPS
well i got the slide pins, part # 2c3z-2c150-aa. well im not sure wich slide pin came out of wich bore. so if any one knows wich pin goes on top and bottom?
though ill try and look closely at the pictures on guzzles page, to try and determin wich pin goes were.
thanks..
Old Nov 15, 2006 | 12:33 PM
guzzle92's Avatar
guzzle92
The slide pin with the rubber sleeve on the tip goes in the top bore of the caliper and the one without the tip (green color) goes in the bottom bore.
Old Nov 15, 2006 | 01:48 PM
2002f2507.3LPS
well i went and bought a 50 to 250 foot pound torque rench, and it busted on me last night. i was going to use it to make sure i got my lugs and those calliper bolts up to 166 foot pounds, well how can i get it right with out the torque rench? i had to use a half inch socket driver and a pipe to extend the handle to get enough leverage on the bolts to loosen them, so should i try and guestimate how tight to make them when i put the callipers back on and the wheels?
Old Nov 15, 2006 | 01:51 PM
2002f2507.3LPS
seems like it should hold till i can get a new Torque rench to check for proper torque of 166. stupid huskey Torque rench, time to take it back to home depto...
tmarat
Oct 23, 2014 08:15 PM
Fordication
2009 - 2014 F150
Jan 2, 2012 04:44 PM
shuttlevalve
2004 - 2008 F150
Sep 3, 2011 05:28 PM
ironwkr416
Dec 17, 2009 06:18 AM
TayzGpa
Jul 4, 2007 02:39 PM
