Sponsored by: Auxito
Light ping under load
Old Nov 19, 2006 | 05:09 PM
eeyore150's Avatar
eeyore150
Trailering
I cleaned my MAF sensor and replaced my fuel filter last weekend. I previously could not run regular gas, and the truck still knocked too much on premium. I've run regular (I think 87 octane) since last weekend and it ocasionaly knocks if conditions are just right, but way better than even running premium before. I still have just a couple slight pings when it upshifts or if I hold it just short of allowing it to kick down. Anyway it's alot better, I'm not sure what to try next.
Old Dec 2, 2006 | 10:17 PM
whimsey's Avatar
whimsey
Spotty, I put the new IAT sensor in and finally was able to empty the 91 octane and fill with 87. I'm happy to report that my colder temp pinging on the same secondary roads has seemingly disappeared. Where it was pinging even with the 91 it doesn't ping now with the 87. I haven't had a chance to test it out on the highway yet but hope to shortly. The $42 for the sensor was well spent in my book. That is about the extra amount that 7 tanks of high test would cost. And it still pinged on high test before I replaced the sensor, only somewhat less than with regular.
Whimsey
Old Dec 4, 2006 | 08:16 AM
Spotty's Avatar
Spotty
Whimsey, hope that it works out long term. After using 2 tanks of 89 octane I thought I would try the 87 stuff again. My truck had less power and mileage dropped about 1 mpg with the 89 stuff, but no trace of a ping. To my surprise I've ran several full tanks of gas ( about 85 gallons) of the 87 octane with no pinging. (OK, maybe a little now and then when it shifts to OD, but very light and not sustained. I will definitely change out the IAT sensor if the problem shows up again on a regular basis. I think this is a logical sensor to replace for this condition if all the other possibilities are taken care of first. Thanks for the reply, hopefully we have all learned a little from this post, and remember guys my truck gets worked each day hauling construction related stuff around in temperature from -20 degrees to 100 degrees, and always starts and runs strong and efficient. I think this is one of the best engines I have ever owned and at 53 years old I've had a lot of vehicles.
Happy Holidays.... Spotty..
Old Dec 4, 2006 | 05:27 PM
apowder97's Avatar
apowder97
Ok what's the IAT sensor?
Old Dec 4, 2006 | 05:49 PM
whimsey's Avatar
whimsey
Intake Air Temperature sensor. In my 2002 F-150 with the 4.6L V-8 it's in the intake air bellows just after the MAF sensor.
Whimsey
Old Dec 4, 2006 | 05:51 PM
apowder97's Avatar
apowder97
Is this the same thing as the IAC? I'm asking because I have a light ping also.
Old Dec 4, 2006 | 05:54 PM
whimsey's Avatar
whimsey
No, the IAC affects the idle speed and stalling when the throttle is closed.
Whimsey
Old Dec 4, 2006 | 05:59 PM
Spotty's Avatar
Spotty
No, IAC is Idle Air Control. This controls the amount of air entering the throttle body-intake during idle, tough to associate this with "pinging" or detonation. If your truck starts and dies but you can keep it running by depressing the accelerator, that could be a symtom of a faulty IAC.
Spotty..
Hogtrapper
Jan 23, 2016 02:13 PM
johnzenobia
2009 - 2014 F150
Jul 12, 2015 01:47 PM
Smitty75
1997 - 2003 F150
Jul 5, 2015 10:39 AM
SDDL-UP
Nov 23, 2014 09:27 PM
TR 1
Modular V10 (6.8l)
Aug 8, 2013 03:54 PM
