Ignition & Door Locks
Old Aug 30, 2002 | 09:40 PM
ozzie 1's Avatar
ozzie 1
Old Sep 10, 2002 | 01:55 PM
skeleton's Avatar
skeleton
Where can I get a replacement ignition cylinder assembly with two door locks and keys for a 1951 ford f-1?
Thanks.
Old Sep 10, 2002 | 02:31 PM
58ford's Avatar
58ford
i know that motor haven has them. you also might want to try lmc truck or even f100.com. that is just a few sites to try. Hope this helps:-X12
Old Sep 10, 2002 | 02:44 PM
darkhorse54's Avatar
darkhorse54
What seems to be the problem, is your ignition switch bad? Sacramento vintage ford sells the door lock cylinders for 1948-52 (matched pair) for $26.00 pt. # 966-5 but they don't list the ignition cylinder, you can go to any lock smith and have them keyed the same.
Old Sep 10, 2002 | 04:01 PM
skeleton's Avatar
skeleton
My truck did not come with a set of keys and the locksmith I called estimated the cost to be between $65 - $85 to cut the ignition key.
I could only find key blanks at motorhaven, door locks at f100, and the ingnition assembly and door locks for the 1953-56 at dennis-carpenter. What is the web address for LMC?
Thanks.
Old Sep 10, 2002 | 06:35 PM
h2orep's Avatar
h2orep
I just got a new catalog from Mid Fifty and they have both ignition switches/keys and the new door lock assembies...
Old Sep 10, 2002 | 08:24 PM
angus's Avatar
angus
[updated:LAST EDITED ON 10-Sep-02 AT 09:40 PM (EST)]If it's like the 57-60 locks, all you need is a key blank and a couple of jeweller's files to do it yourself. Fitting keys is not brain surgery: if you understand how the cylinder lock works it is obvious how to cut a key to fit (install one pin at a time, file the key until the lock turns, then put the next one in and repeat). Just don't lose the tiny springs when you take the cylinder apart.
Look through the alt.locksmithing FAQ (see section 13 on re-keying):
http://www.non.com/news.answers/locksmith-faq.html
Old Sep 11, 2002 | 09:26 AM
51f1's Avatar
51f1
I've been looking for new locks for my '51 also. Mine have a door that swings over the keyhole. I've found replacements...but not with the door.
I've been hesitant to take them apart to re-key them myself.
Old Sep 11, 2002 | 06:32 PM
58ford's Avatar
58ford
the link is www.lmctruck.com. you can't look at their nventory online but the catalog doesn't take long to get. I've been very satisfied with their values and their delivery time. Hope this helps. Happy Fording
