Holy Crap!
Old Nov 7, 2006 | 06:58 AM
shenders99's Avatar
shenders99
Holy Crap!
So this starts last night when I decided to pull some codes.
P1247 Turbo Pressure Boost Low
P1248 Turbo Boost Pressure Not Detected
P1211 Inject. Control Pressure Above/Below Desired
First thing I did was tighten my boots that were considerably loose on the hot side.
Then wham, boost up to 28 psi. Wow. I've never been past 19-20 psi nor have I tried. I never even realized that I had a problem.
Anyhow, I tried to pull codes after my trip in to work today and nothing. I was hoping that I would not have to get a new MAP sensor as well.
Anyone else every have a similar experience?
I am going to pull codes daily to see of any of them come back...
Old Nov 7, 2006 | 07:08 AM
Uzumati's Avatar
Uzumati
the 1211 could just be from the tune Jody calls for higher ICP than stock.
Unless you have a blockage between the map hose connection on the Y and the map sensor it is probably the map. If your gauge is reading correctly look between its tap and the MAP if the gauge is reading low check the Turbo (EBPV stuck, Wastegate stuck, dusted wheel, ect)
Old Nov 7, 2006 | 05:56 PM
shenders99's Avatar
shenders99
So I pulled codes again tonight and nothing new. Is it possible that the p1248 was just a side effect?
Old Nov 7, 2006 | 06:16 PM
Uzumati's Avatar
Uzumati
very possible........... i missed about the loose boots on the first read
Old Nov 7, 2006 | 06:26 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
shenders99,
p1211 is as what amiller93 explained.
(p1248, 1247) - Description- turbo boost pressure low, turbo boost pressure not detected.
Known causes- Turbo MAP hose, sensor, EBP sys, intake leaks.
This is what I took straight from the ford OBDII codes lists.
let us know what you find.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Nov 7, 2006 | 07:42 PM
shenders99's Avatar
shenders99
Update:
I cleared the codes last night and found that my boots were considerably loose.
I initially never experienced more than 20 pounds of boost and can now get it over 26 pounds. That was obviously the p1247 problem.
I understand that the P1211 could be the DP Chip.
I ran it hard (no trailer) today and check for more codes but found none. I wonder if the MAP is okay and p1248 a side effect.
Old Nov 7, 2006 | 07:50 PM
Uzumati's Avatar
Uzumati
I would keep an eye on it but as long as it doesn't return you shoul dbe OK. What are you using to pull codes? if it has the ability to monitor PID's you can keep an eye on MAP while driving to be sure you are not getting an intermittant failure
Old Nov 7, 2006 | 08:05 PM
shenders99's Avatar
shenders99
I am using my old edge evo. I think that it can monitor things. I would like to pick up AE though.
Old Nov 7, 2006 | 08:12 PM
nikates's Avatar
nikates
im being told on another site that the injector code is the truck not getting enough fule and they told me to put a new fule pressure spring in.
Old Nov 7, 2006 | 08:18 PM
Uzumati's Avatar
Uzumati
Then they have no idea how the systems on the powerstrokes work.
ICP monitors the high pressure oil system that drives the injectors. it has nothing to do with Fuel pressure
Old Nov 7, 2006 | 08:25 PM
nikates's Avatar
nikates
then whats the code mean i get it every time i hit 90mph's when on the high setting of my programmer?????????????
Old Nov 7, 2006 | 08:44 PM
Uzumati's Avatar
Uzumati
1211 is common when using a programmer all it means is the ICP is reporting an oil pressure outside of the range expected for the given throtle position and boost level
Old Nov 7, 2006 | 09:00 PM
nikates's Avatar
nikates
can it result in anything bad?
Old Nov 7, 2006 | 09:02 PM
nikates's Avatar
nikates
also i pm'ed you
Old Nov 7, 2006 | 09:12 PM
ryaneverk2's Avatar
ryaneverk2
Just that annoying SES light (and that nagging knowledge that you could have more power with Big Oil which would get rid of the light and code).
