Sponsored by: Auxito
under load bucking...
Old Nov 7, 2006 | 06:31 AM
gui88ford's Avatar
gui88ford
hey everyone,
i'm noticing a bucking starting to get worse for me.....basically only happens up to around 2,200 RPM's....then clears up....1st through 4th gear....2nd and 3rd being the worst...my truck is a 5 spd also...
i was thinking clutch.....truck has a little over 80K....origional clutch.....
no check engin light either....thats one reason i'm thinking clutch...
thanks for the help...
Old Nov 7, 2006 | 06:43 AM
projectSHO89's Avatar
projectSHO89
Probably plugs/wires.
They dont always set a CEL until the misfire gets severe enough.
Steve
Old Nov 7, 2006 | 06:57 AM
gui88ford's Avatar
gui88ford
mine has COP's...
Old Nov 7, 2006 | 08:07 AM
valiantski's Avatar
valiantski
it could be one of your coils.
Old Nov 7, 2006 | 08:57 AM
gui88ford's Avatar
gui88ford
how would i go about testing them to find out if one is bad or not????
Old Nov 7, 2006 | 09:22 AM
VetteTech81's Avatar
VetteTech81
This is where the fun starts.. you can pull them one by one and use a spark tester set the gap large and see if you have consistant spark.. if you find a weak one, replace it and the plug.. there is other ways I am sure.. anyone else have some suggestions? Of course I would want to see if there is any scan data that may help like missfire counters that would cut the chase shorter..
-=Rick
Old Nov 7, 2006 | 09:30 AM
scottie2hottie's Avatar
scottie2hottie
most parts stores can test the coil- take em up there and have them test all of em
Old Nov 7, 2006 | 10:31 AM
projectSHO89
mine has COP's...
Okay, then...you didn't say what year and engine you have....
My answer now is - probably plugs/COP.
A scan tool that reads Mode 6 data will display the MISFIRECNTs for individual cylinders long before any misfire DTCs are set. of course, these scan tools are not at your local auto parts stores. A decent independent shop or a Ford dealer (of course) will have one.
Steve
Old Nov 7, 2006 | 10:59 AM
gui88ford's Avatar
gui88ford
it's a 2001 4.6 L
59flatbedford
15
Jan 20, 2016 03:46 PM
arkredneck
16
Jun 13, 2015 06:51 AM
dieselsubmariner
Jan 10, 2015 12:09 PM
Tony G
Jul 15, 2004 01:35 AM
