1978 - 1996 Big Bronco
3g writeup
Old Nov 6, 2006 | 08:13 PM
chrono4's Avatar
chrono4
3g writeup
Anybody have a 3g alternator upgrade writeup? I'm in bad need of more charging amps, running fog lights, 2400 watts of amps, computer, 8 inch monitor, and the stock alternator just cant keep up. I was looking into the 3g, but I need to know exactly what I need because this is my Daily driver, so it cant be down for long. Thansk guys.
Old Nov 6, 2006 | 09:10 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Don't know who has a writup there is one on fsb.com but basically you need one from a late 90s mustang or truck, I think.
But the wiring from your external reg. needas to be extended to splice into the 3gs plug.
You should be able to locate the field, sences and excite wires from the reg.
Then the 12v should just be upgraded to a 4ga. wire or you could even go 2ga. if you want.
Old Nov 6, 2006 | 11:35 PM
masseysbronco's Avatar
masseysbronco
Thumbs up
Here you go http://fordfuelinjection.com/?p=75 hope that helps a little. I would reccomend just building a new harness rather than splicing and extending the old one though. Its only a few wires and you never know what shape their in half way down the harness.
Old Nov 7, 2006 | 12:06 AM
Bdox's Avatar
Bdox
Maybe a lead for you: https://www.ford-trucks.com/forums/4...rnator+install
Here's another: https://www.ford-trucks.com/forums/4...rnator+upgrade
hail destroyer
Sep 22, 2016 01:42 AM
BearFootCustom
19
Mar 25, 2016 06:51 PM
thecodemonk
Apr 29, 2015 08:07 PM
nothercrash
Apr 13, 2011 07:32 PM
ccopes75
Sep 9, 2007 09:44 PM
