Charging System Upgrade
Old Jul 14, 2007 | 07:07 PM
ccopes75's Avatar
ccopes75
Ive got a 69 F100 with a 390. I want to upgrade my charging system(on a budget ) and I need some basic info. First, is the stock unit a 1G alternator? If so will any 1G fit or is it vehicle specific? Has anyone had any problems with a 1-wire unit like low output? I would like to go 1-wire if I can. Maybe a Powermaster 140 amp unit. Also I have read about upgrading to a 3G. Will a 3G fit without any modification to the brackets. Thanks for the help.
Old Aug 3, 2007 | 02:40 PM
amish77's Avatar
amish77
The one ground (I think this is what you are talking bout) is interchangeable with others. Try getting your stock alternator re-wound by a local alternator rebuild shop. This is WAAAAAAAYYYY cheaper than buying another one, and you can get it wound up to 200 amps in most cases. A buddy of mine got it done for about $140.
Old Aug 3, 2007 | 05:32 PM
Bear 45/70's Avatar
Bear 45/70
What do you need all that alternator power output for? I just picked up a 1992 Crown Victoria Police Interceptor and it only has 140 amps alternator for all the radios and lights. Even with 4 batteries, 2 under the hood and 2 in the camper, 90 amps was way more than enough.
Old Sep 8, 2007 | 10:02 PM
amish77's Avatar
amish77
Extra amps help keep the voltage constant under draw, which in turn helps keep the batteries from tanking on you. Also a big stereo needs a LOT of amps to keep the voltage steady.
Old Sep 9, 2007 | 01:34 PM
Bear 45/70's Avatar
Bear 45/70
If you are running a big stereo that loud as you go down the road, you are just plain being unsafe. You need to hear the other guys horn. Besides that a stereo, in what for all practical purposes is a 55 gall drum, makes no sense what so ever. On top of that, it's a truck for God's sake, act like it.
Old Sep 9, 2007 | 09:44 PM
ccopes75's Avatar
ccopes75
Mainly, I like the powermaster 1-wire alt for the look. I just wanted to know if anyone had upgraded and if so, how it worked out for them. I am in the process of adding a amp and sub however, so the added power my be needed to keep it bumping.
