If you keep the hubs locked just to avoid having to get out and lock them when you need to, one of two things will happen. (1) you'll be lucky to only increase wheel wear, or (2) you may break something (i.e. axle) because the front axle is a locker with no differential.
No, this is an incorrect statement. You will not break anything with the front hubs locked driving around with the transfer case in 2WD. The front axle is not a locker and there Is a differential in the front axle. The only thing that occurrs with the front hubs locked and the transfer case in 2WD is the front axles turn and the front drive shaft turns, This causes a slight increased drag on the drive train (do to more turning parts) so fuel mileage may go down slightly.
FYI the only thing in a traditional 4WD system (like installed on all SD, be it ESOF or Manual Levers), that works like a locker and has no differential, is the transfer case. When the transfer case is in 4WD mode, the front and rear axles are effectively hooked together with no differential between them. This can cause binding of the drivetrain and potential damage/breakage of drive train components when driven on Dry Pavement. Hence the reason to use 4WD on slick roads or off road only.
Now if a vehicle has a Full Time 4WD system then there is a differential in the transfer case also, and therefore you can drive on dry pavement safely.
were dose the vacume get created for the auto hubs? and also i get like a reading of 13 or so on the driver side rubber hose with a vacume tester, and nothing on the passenger side, wich may explain the hard turnning of the auto to manual switching on the passenger side apposed to the easy turning on the driver side.
The issue seems to be with the seals drying and creating a vacuum leak. I've talked to my local Ford mechanic and he did not give me the impression they were designed very well. My dad has a 2000 F-250 with the hubs out, my friend had his replaced about 8 months ago, and mine last January. The hubs are about $450 apiece plus labor.
I have an 02 F-350 and my drivers side bearing was going out and I just had it replaced, I ended up having the other side done as well
I paid $740 with parts and labor, not Ford parts, but same 1 yr warranty
The "hubs" are actually a whole piece bearing assembly that bolt to the spindle
