power steering problem
Old Nov 6, 2006 | 03:56 PM
jeremy18's Avatar
jeremy18
hi, i just bought a 1975 f-250 highboy with a 460 including headers and 36 in super swampers. but my question is i have a problem with my power steering, when i bought it there wasnt any fluid in the box and the bozo that had it before me had gear oil in that box and i went ahead and put more in there to fill it up. but my power steering still isnt working what should i do?
Old Nov 6, 2006 | 04:21 PM
holland501's Avatar
holland501
You mention the 'box'. What about the pump?
Old Nov 7, 2006 | 09:06 AM
1975Ford's Avatar
1975Ford
Does your truck have the power steering lines that goes to the hydraulic ram on front axle and the check valves on center link?
Old Nov 7, 2006 | 12:51 PM
badgtho's Avatar
badgtho
a 75 has power assist. it should take ATF. if its OE to that truck, it should have a garrison type i beleive.
there are about a million issues that the thing could have. ... pump, ram, control valve.. etc.
Old Nov 8, 2006 | 02:25 PM
jeremy18's Avatar
jeremy18
it has a pump i just wanted to know if it was the gear oil instead of power steering fluid in the box which was my problem or would i need to change my pump or something else
Old Nov 8, 2006 | 02:41 PM
badgtho's Avatar
badgtho
if you read above then you will see it takes ATF my friend. Not gear oil, not Power steering fluid, Not engine oil, Not brake fluid, Not water.
Old Nov 8, 2006 | 02:52 PM
jeremy18's Avatar
jeremy18
i know but thats what the guy before me put i know thats not what it needs. my question was that having those substances in there my power steering problem or do i need a new pump?
Old Nov 8, 2006 | 02:55 PM
badgtho's Avatar
badgtho
well like i said. there are several components that can cause the issue. i have no idea why you;ve settled on a pump... but the ram or control valve are very likley candidates.
Old Nov 8, 2006 | 02:56 PM
1975Ford's Avatar
1975Ford
Does the steering gear box have any power steering hoses going to the steering box?
Then the steering box does take gear oil. There is a plug on top, which is used to refill the steering box.
Are you talking steering pump or steering box?
Can you rephrase the other question?
Old Nov 8, 2006 | 02:57 PM
jeremy18's Avatar
jeremy18
ok thank you. sorry im only 17 i dont have any mechanic experience just an older brother telling me its the pump
Old Nov 8, 2006 | 02:59 PM
1975Ford's Avatar
1975Ford
We are here to assist you.
Old Nov 8, 2006 | 03:00 PM
badgtho's Avatar
badgtho
if he has a garrison type setup on the 75 it takes ATF.. right?
Old Nov 8, 2006 | 03:02 PM
1975Ford's Avatar
1975Ford
The power steering system (pump, hoses, ram, control valve) run with power steering fluid, type F.
I am unsure what type of steering setup he currently has?
jeremy18, we need more info and answers to the questions.
jeremy18's Avatar
jeremy18
so if my ram or control valve is the problem do i replace them or have them rebuilt?
Old Nov 8, 2006 | 03:05 PM
badgtho's Avatar
badgtho
I am unsure what type he currently has?
so which type are you saying takes the gear oil? i have had pretty much every type of these trucks. i currently have a 73 250 retrofitted to a 75 ram assist. i put ATF in it.
the newer 77.5-79s take steering fluid.
Jeremy... if you do have ram assist, then there are 2 versions. post a pic and we can tell you which you have.
if either are bad its better to buy a rebuilt.
