Offroad & 4x4
4.10s or 4.11s gears??
Old 11-05-2006, 11:25 PM
hatchet's Avatar
hatchet
hatchet is offline
did stock f 250s from 96 come with 4.10 gears or 4.11s?sorry i forgot just checking on something thanks......
Old 11-05-2006, 11:56 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
they are essentially the same. the differet air pressure in your tires make more of a difference than 1/1ooths of an inch differnce in gears!
also, usually front axles have a slightly deeper gear than the rear. example... front D60 has 4.11's and the rear has 4.10's
-cutts-
Old 11-06-2006, 01:13 AM
hatchet's Avatar
hatchet
hatchet is offline
really i didnt know that guess i orderd the wrong gears then tHey sent me 4.10s for my dana 60 front and 4 10s for the ford sterling 10.25.ill call ford in the AM and see what they say.thanks for the info
Old 11-06-2006, 09:32 AM
billybob_81067's Avatar
billybob_81067
billybob_81067 is offline
That'll be fine... my 69 F-250 has 4.09 in the front and 4.10 in the rear.
Old 11-06-2006, 09:42 AM
hatchet's Avatar
hatchet
hatchet is offline
ok one question is it your daily driver?
Old 11-06-2006, 02:11 PM
billybob_81067
Yes it is my daily driver. (bet you didn't expect someone to have a 69 as a daily driver!) Having mismatched gears front and rear by .01 makes no real difference. The only thing you don't want to do with it is run it in 4x4 on dry pavement.
Old 11-06-2006, 02:24 PM
hoxiii's Avatar
hoxiii
hoxiii is offline
Your truck will not know the difference between 4.10's, 4.11's, 4.09's, whatever. For all intents and purposes they are all the same. You don't really run ito an issue until you try something like running 3.73's in one axle and 4.11's in another.
For a D44/9" combo ford calls 4.09's and 4.11's a matched set from the factory. A D44/8.8 4.09's and 4.10's are a matched set. All they have to be is close (within about 5%)
Justin
Old 11-08-2006, 06:39 PM
LedheadELH's Avatar
LedheadELH
LedheadELH is offline
yea, I've got a truck w/ a 3.55 9" in the rear, and 3.54 D44 in the front, they did that from the factory to help with driveline windup.....it really makes no difference in the world.....I've even run a bigger split than that...I forgot what it was exactly, but it was a 16% difference, and as long as I never hit the tar w/ it, it was fine!....
Old 11-09-2006, 10:53 PM
302s&460srocks's Avatar
302s&460srocks
302s&460srocks is offline
it's good enough for pavement as long as there is no more than 1% difference between front and rear... from what I've read
Old 11-10-2006, 10:59 AM
kjg26's Avatar
kjg26
kjg26 is offline
i've heard of all the way up to 5% diff. as long as it's not full time 4x4.
Old 11-10-2006, 11:21 AM
LedheadELH's Avatar
LedheadELH
I know that a .01 gear difference is what they all do from the factory, so I would imagine that should be fine for on the road, I'm pretty sure that's why they do that, so you don't have driveline-windup as they call it, on the road.....
Old 11-10-2006, 03:05 PM
bremen242's Avatar
bremen242
bremen242 is offline
I believe it has more to do with the diameter of the ring gear and how many teeth they can fit on the ring gear.
Old 11-10-2006, 03:51 PM
LedheadELH's Avatar
LedheadELH
no, it has nothing to do w/ that, they can make a gear set w/ however many teeth they desire, BUT, the factory makes the front end w/ a .01 taller gear, to prevent driveline windup on the road.
Old 11-10-2006, 08:46 PM
captain p4's Avatar
captain p4
captain p4 is offline
they make them different to prevent driveline bind? that doesn't make much sense.
The newer trucks all have the same front and rear. Plus there is no reason to worry about drive line bind on the road unless you're using 4x4.. and you only use that in less than optimal conditions, which generally allow the tires to slip.
Old 11-10-2006, 09:43 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
They have different ratios front and rear due to the ring and pinion sizing, and in some cases, different axle manufacturers front and rear(Ford half tons for example.) You will find 3/4 and 1 tons with both diffs by the same manufacturer, with the same ratio front and rear. Heck, I know that 80-83 or so F150/BKO 4x4's with 9" in the rear with 3.00 or 3.50 gears came with matching 3.00 or 3.50 gears up front... Just check the Dana expert if you don't believe me.
Quick Reply: 4.10s or 4.11s gears??
