4.10s or 4.11s gears??
on
It has nothing to do w/ gear size, it also has nothing to do w/ "Plus there is no reason to worry about drive line bind on the road unless you're using 4x4" that comment, (which makes no sense at all), it is so when your going on tar, in 4X4, it goes smooth, if you don't believe me, call Ford Motor Company!
and no not EVERY truck EVER made came like that, but the majority of them did, not jsut ford, but any manufacturer.
and back to that comment about "Plus there is no reason to worry about drive line bind on the road unless you're using 4x4" your whole post makes no sense. they split the gears for using 4X4 on the road. many people will hit dry tar at SOME point in their truck's life in 4X4, and Ford knows this. That's why they split the gears, so that when these people w/ their brand new trucks hit the tar in 4X4, and it's kinda rough, they don't come back saying something is wrong w/ their truck. you must also remember, what about the old Full Time 4X4 trucks from back in the 70's and such.....there was no putting those trucks IN 2WD, so do they never use 4X4 on the tar?, or in bad conditions?, no they do it everytime they go down the road.
I know about the gear difference thing not by word of mouth, or some old guy told me, I know it stright from the MANUFACTURERS!
Originally Posted by Beemer Nut
How do you split a tooth to get .01? I'm all ears.
DUUUUUUUUUUUUUUUUUHHHHHHHHHHHHHHHHHHH
-cutts-
on
well I remember it from a book I read like 5 months ago, and I finally found where in the book it was, so here it is, straight from the book,
"Although the difference between the ratios is small, the purpose is to prevent the driveline from binding. With the front differential ratio just slightly higher, the tendency is for the front of the vehicle to pull the vehicle thereby eliminating the problem of having the rear pushing at the same ratio as the front pulling. The different ratios also help reduce resonant vibration and noise created in the driveline."
All the information in this book is from engineers from Ford, GM, Chrystler, Honda, and Toyota mostly, and a few other stupid foreign companies.
Now I hope we can put this to rest....I hope
BTW, it is not always .01. That is just how Ford did it in their trucks, I have no clue what other manufacturers used for a difference
Originally Posted by 82F100SWB
They have different ratios front and rear due to the ring and pinion sizing, and in some cases, different axle manufacturers front and rear(Ford half tons for example.) You will find 3/4 and 1 tons with both diffs by the same manufacturer, with the same ratio front and rear. Heck, I know that 80-83 or so F150/BKO 4x4's with 9" in the rear with 3.00 or 3.50 gears came with matching 3.00 or 3.50 gears up front... Just check the Dana expert if you don't believe me.
My 2000 F150 has 3.73s front & rear.
Besides, if it had something to do with drivetrain binding, instead of the front binding, the rear would cause a bind as well.
and if you think the front should be pulling the rear, try running 3.27s in the front of your truck and 3.50s in the rear. Then go drive it in the snow/ice. You'll find it isn't a good idea either.
the point .01 difference can be made up with tire wear and air pressure.
then why did my '00 f150 have 3.55s front and rear if my comment makes no sense at all? I don't think my dive line exploded as i drove down the road.
Like everyone else has been trying to tell you, that .01 can be made up with tire pressures and wear, it really makes no difference and is not done on purpose.
on
Like I said, not all trucks had them, but many did. and that is the reason they did it. It may have been more of the older trucks that did, because their parts were more of a positive engagement, w/ all gear transfers, alxes w/ U-joints, instead of CV's. I really don't care if you guys don't believe me or not, it's your mistake not mine.
Like I said, call the manufacturer, and ask them
My bronco originally had matching 3.50 gears, w/ the 9", and D44, but the D44 I swapped into it that was leaf sprung out of a F-250, had 3.54.
Another truck I have has a 9" w/ 3.55 and a D44 w/ 3.54.....it's a '70.....like I said, I think it was an older truck kinda thing, like pre-80's
Diameter of the ring gear?
difference of .01?
Be the ring gear 8" or 10' with the same tooth count nothing changes.
Ratio of tooth count between ring and pinion unless you have a new angle on the laws of mechanics?
difference of .01?
In short, for those that think ring gears somehow are smaller or larger diameter when you change the gear ratio, they're not. It's physically imposible to install smaller or larger ring gears into a diff they don't belong in. It's also impossible to use the pinion gear from a different gear ratio, because in order to change the ratio, the number of teeth on the pinion gear likely has to be different and/or gears come in matched sets and the sets must be used together.
In this case the FACT is they did it cause thats what they happened to get from the gear manufacturer, not because it was a thought out anti windup engineering decision.
Let me give you some examples just on my own vehicles I have owned with factory gearing, 1969 F100 4.09 front, 4.10 rear, (D44, D60 combo factory) 1969 F100 D44 9" combo. 4.11frt 4.10 rear hmm guess they couldn't make up thier mind in 1969 which way to go. 1973 F150 D44/9" 3.54/3.50, 1974 F150 same axles 3.50/3.55 both factory, 1974 D44/*" 3.54/3.55. 1986 D44/8.8 3.08/3.10 1981 D44/9" 3.08/3.00 both factory gears. Your theory doesn't hold up cause they switch back and forth so that book was written just to make it sound like they were so smart and thought it out, and it just ain't so sorry.
most newer trucks have axles matched with manufacture. My Ford has a Ford front and rear. Chevy's and Dodge's have AAM axles front and rear.
F250s after mid 85 had ford corporate rears (ie the Sterling 10.25") instead of a Dana 61 or 70 (which had 9.75" and 10.50" ring gears). Guess what, Sterlings had 3.55s instead of 3.54s.
Compare the ring gear size, gear ratio & teeth count between different axles and manufacturers.
FORD 8.8" RING & PINION
3.55 Ratio, 39-11 Teeth
3.73 Ratio, 41-11 Teeth
4.10 Ratio, 41-10 Teeth
4.56 Ratio, 41-9 Teeth
FORD 9" RING & PINION
3.50 Ratio, 35-10 Teeth
3.70 Ratio, 37-10 Teeth
3.89 Ratio, 35-9 Teeth
4.11 Ratio, 37-9 Teeth
4.86 Ratio, 34-7 Teeth
FORD 9.75" RING & PINION
PART # TEETH RATIO
F975/308 OEM 40-13 3.08
F975/331 OEM 43-13 3.31
F975/355 OEM 39-11 3.55
F975/373 OEM 41-11 3.73
F97/410L * T/L 41-10 4.10
F97/456L * T/L 41-09 4.56
FORD 10.25" RING & PINION
E5TZ4209B 39-11 3.55
E5TZ4209C 41-11 3.73
E5TZ4209D 41-10 4.1
E5TZ4209F 41-09 4.56
DANA 44R 8.5" RING & PINION (reverse cut front)
28769-1X 42-12 3.50R
24638-1X 46-13 3.54R
24647-1X 41-11 3.73R
24649-1X 45-11 4.09R
D44/456R USG T/L 41-09 4.56R
D44/488R USG T/L 44-09 4.88R
D44/513R USG T/L 41-08 5.13R
DANA 70 10.50" RING & PINION
72168-5X 46-13 3.54
72154-5X 41-10 4.10
72152-5X 41-09 4.56
72148-5X 39-08 4.88
72156-5X 47-08 5.86
'86 F150
1978 - 1996 Big Bronco
22
06-16-2014 08:22 PM
Dan92
30
05-16-2012 07:44 AM
dougbrown
02-03-2011 10:39 PM
