Tranny not shifting
Old Nov 5, 2006 | 08:37 PM
ArcticMotorsports's Avatar
ArcticMotorsports
Tranny not shifting
From a stop, it will shift from 1st to 2nd just fine and then will redline the truck in 2nd and the rpms will vary. Some times you can get it to shift by getting on and off the throttle, does the same thing when trying to go from 3rd to overdrive but even harder to try to get it to shift. The overdrive off light will start to flash. After the truck has this problem and you shut it off and come back to it, reverse is gone, nothing there till you put it into drive and then come back to reverse and its fine. Take off from where you are and the tranny acts perfect, no issues. Somedays you can go the whole day and never have a problem. So this problem comes and goes. Below are the codes I got from the computer. Let me know if theres any other info I can get/tell you to help get an idea of whats wrong.
P0722 Gear 3 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P1728 Trans Slip Error Convertor Clutch Fault
P1247 Turbo Boost Pressure Low
Old Nov 5, 2006 | 09:03 PM
Uzumati's Avatar
Uzumati
Here's the Pinpoint A test it deals with the electronics side
File Type: pdf
Old Nov 5, 2006 | 09:26 PM
ArcticMotorsports
I dont have the tools to do most of what they ask on that. Sounds like I just need to take it in.
Old Nov 6, 2006 | 07:17 AM
Casey's Avatar
Casey
What truck? What engine? What trans? Without that all I can tell you is that something's wrong.
Old Nov 7, 2006 | 04:09 PM
ArcticMotorsports
99 F-350 4x4 Powerstroke Standard Cab
