1990 f250 timeing problem
Old Nov 5, 2006 | 07:12 PM
rjdxjpp's Avatar
rjdxjpp
ok so i bought the truck and the timeing was all messed up and i figured it would be an easy fix so i went out and bought a timeing light and now i cant get it right. i hooked the light up and set the timing to the original mark then tightend the distributer back up and it still nearly dies when idleing. obliviously im doin somthin wrong. could i have to adjust the idle or something if so how do i do that?
Old Nov 5, 2006 | 09:01 PM
Fully_Loaded's Avatar
Fully_Loaded
You need to take the spout connector out and then set to 10 degrees BTDC.
