How to remove tailgate from '94
Old Nov 4, 2006 | 04:37 PM
Supercab's Avatar
Supercab
Wink How to remove tailgate from '94
How do I remove the tailgate from my 1994 F150??
Old Nov 4, 2006 | 04:50 PM
MustangGT221's Avatar
MustangGT221
Open it, slide off the cables at the top (where they attach to the bed), and while holding the tailgate, wiggle the right side loose from the mount. It's got a slotted hole that it comes out of...and the left side will pop out when you get the right side out.
Be careful, first time you might want a partner.
Old Nov 4, 2006 | 05:20 PM
McLeod's Avatar
McLeod
To add to what MustangGT221 said:
The hinge disengages at about the tailgate half way down point.
Old Nov 4, 2006 | 09:33 PM
Supercab's Avatar
Supercab
Wink
Thanks guys!!!! I knew this couldn't be that hard-I'd seen it done, but never really paid much attention as to HOW.
The reason I'm needing to take the tailgate off momentairly is to install my new LED light "bar" that extends almost end to end under the tailgates bottom lip-incorporates running lights, brake, and turn signals (and looks pretty cool, too!!!!)
Old Nov 5, 2006 | 09:17 PM
MustangGT221
If you want, you can do a write up on the install and results for FTE...not sure if you've seen this...
https://www.ford-trucks.com/forums/f...uncements.html
Let us know how it looks.
