Anyone have a trans temp sender?
Old Nov 5, 2006 | 06:11 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
My transmission temp sender has been broken since i installed it, and i want it to work. I have a Autometer single wire sender. Does anyone have one they would like to sell? Thanks FTE.
Old Nov 5, 2006 | 06:54 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Kris, just to make sure I have the right one. Is the total length of the sensor, end to end 2 inches? From the end that goes into the tranny to the threads is 3/4 of an inch? If this is what you need then PM me your address.
Old Nov 5, 2006 | 07:06 PM
PowerstrokeJunkie
Yeah, that sounds about right. There is a white electrode-looking thing that is plastic on the outside, with a small nut or two on the end? Thanks, ill send you a PM here if that sounds correct.
Old Nov 5, 2006 | 07:19 PM
RAMPAGE_F350
Sounds like we have a match.
When I had Garrett send me a replacement sender (the one I overtightened) I also called Autometer. So I ended up with a spare, I just wanted to make sure about the length.
