1978 - 1996 Big Bronco
302 problem need help fast
Old Nov 5, 2006 | 10:54 AM
bbwrench's Avatar
bbwrench
Exclamation 302 problem need help fast
I have a 84 bronco with a 302 c6 in it. It sat in the driveway for 3 months not being driven. It ran fine when I parked it, but now when I fire it up it runs fine when the carb is at high idle till the engine warms up, then when you hit the kick down to idle the engine misses real bad. You can try giving the motor gas after the engine warms up & the motor acts like the throttle isn't even there, then the motor eventually stalls out. I can smell a hint of gas fumes but the motor seams to be getting enough fuel. I need to get this figured out soon so i can get state inspection done. Thanx for any help BBWRENCH
Old Nov 5, 2006 | 11:15 AM
pmibach's Avatar
pmibach
did you put new fuel in it, that might help
