One fouled plug
Old Nov 6, 2006 | 10:36 PM
1975Ford's Avatar
1975Ford
norvillebob, here you go >>> https://www.ford-trucks.com/article/...le_Secret.html check and follow the Valve Clearance Testing and Adjustment.
I'm sure other forum members will have more usefull advice.
Old Nov 7, 2006 | 08:32 AM
Redmanbob's Avatar
Redmanbob
WELL SOB!! I went by Christs's book and checked preload to be near .18 some at least .20 .. Come to find out the 66/352 is in a whole nother janra for preload.. Figures..
Thanks for the link Buck... Guess I know whats on the menu for next weekend.. might explain the engines odd idle that cant be traced down...(longer pushrods!!) are in need. Details to come.
Old Nov 7, 2006 | 08:38 AM
1975Ford's Avatar
1975Ford
Redmanbob, I'm in the same club, I will be checking vavle preload in a couple of weeks, my #7 cylinder has a miss, good spark but a miss, I think the pushrods might be too long. Compression test is good, spark is good. When I pull the plug wire on #7, there was no change in engine idle. I haven't checked the spark plug wire, but this spark plug wire has a good spark.
Old Nov 8, 2006 | 04:45 AM
norvillebob's Avatar
norvillebob
Well, um, a,a, a I uh , um er , changed my brand new cap. And, er , um , it seem to be running much, much ,much, better. Rookie mistake.
I blame my wife she made me clean up the yard the other day and I threw out the old orig. cap. It was a blue streak the "better than stock" lifetime warrenty one. In hindsight looking in the cap several times, the brass posts were off-center??
I can't say for sure %100 cause I caused another problem last night when I was fooling with it. I burned a hole in my cable shifter . And it's stuck in 1st.
thanks all
bob
Old Nov 8, 2006 | 07:39 AM
Redmanbob's Avatar
Redmanbob
Yep that truck should defenantly come play with mine.. we'll get you a toyota or ?
Old Nov 8, 2006 | 08:35 AM
norvillebob
I have a toy it's my DD 274K on the clock. 88 landcruiser.
bob
Old Nov 8, 2006 | 08:46 AM
1975Ford's Avatar
1975Ford
norvillebob, Is the miss gone?
Toyota on a Ford Forum? I got two 1978 Toy Landcruisers and a 95 camry. And two GEO prism (their Toyota's badged GEO).
But I love my FORD'S the best.
I haven't really looked at the FE engine, been messing around on the nieces Honda Fuel pump and relay system, it's a no fuel problem.
Old Nov 8, 2006 | 09:22 AM
1975Ford's Avatar
1975Ford
Redmanbob, are there different preloads for the 352FE? Have you had a chance to look at the engine?
I don't have the Christ book, but I do have a bible.
Old Nov 8, 2006 | 09:36 AM
norvillebob
I believe the miss is gone. I started it, much better. Idled with our shaking. Warmed it up. My tach died so I was trying to set the idle by ear. So I put it in D and listen adjust up a notch and : "HEY! I'm still moving" HAd to shut her down and have one of the kids move the gear selector to see what was happening. I melted a hole in the cable shifter on my header. I hated that quick silver thing anyway. So she's blocked up and stuck in gear. But it sounded a whole lot better. However I won't count my chickens before I have scrapple for breakfast.
bob
I'm ordering a unimatic shifter by B&M looks like a 4spd.
Old Nov 8, 2006 | 09:38 AM
Redmanbob's Avatar
Redmanbob
Christs book has preload at .10 -.20 and if you browse that link you posted up on the pushrods it clearly states
{Clearance between the rocker tip and valve should be between .100 to .200 for all FE?s but the '65 to '67 352. The 352 specification is .050 to .150. If there is more slack than is recommended, then a longer push rod is necessary to bring it into specification.}
I'll be reviewing the situation this weekend. NO$$ till then..
Old Nov 8, 2006 | 09:39 AM
1975Ford's Avatar
1975Ford
Chuck block those wheels for saftety.
Old Nov 8, 2006 | 10:07 AM
norvillebob
inflated 31x10.50's fore and aft.
bob
Old Nov 8, 2006 | 01:23 PM
  #28
1975Ford's Avatar
1975Ford
Chuck block for safety, with a wooden block or some large object on front and back of tires, to prevent the vehicle from rolling forward or backwards.
Old Nov 8, 2006 | 01:32 PM
  #29
norvillebob
Yep, I use 31x10.50's on the flat wedged behind the rear right and in front pass.
bob
Old Nov 8, 2006 | 01:39 PM
  #30
1975Ford's Avatar
1975Ford
Just making sure. I always try to reassure safety first during all projects.
I had a buddy mine, messing with the transmission linkages, and he took the transmission out of park, and the vehicle rolled on top of him. Luckly his father was there to save the day. He has the scars on his back where the cross member bolts and vehicle were resting on his back.
