390 t0 427?
Old Nov 4, 2006 | 09:56 PM
arctic y block's Avatar
arctic y block
Talking 390 t0 427?
The original owner and bulider of the engine in my 66
f350 just informed me that he had the block board a stroked to 427. Said he will locate the build sheets and show them to me. I wander is this possable. Or is he full of it. all I know is this truck will burn the possie duels of at a rolling start in 3rd. and will put on a smoke show in 4th gear. It is a 390 by the numbers. can ya bore them that far?
Old Nov 4, 2006 | 10:41 PM
Bear 45/70's Avatar
Bear 45/70
Not likely. The number of 390 blocks (4.05" bore) that have enough meat in the cylinder walls to bore them .180" to the 427 (4.23" bore) are next to nil. The stroke is the same so you don't stroke a 390 to make it a 427. You might bore and stroke a 390 to 428 (4.13" bore, and 3.98" stroke, done that), but not 427. Me thinks someone does not know much about FE motors and is trying to smoke you. Also just cause he has a piece of paper that says it was done, doesn't mean it was done to that motor or any motor for that matter.
Old Nov 5, 2006 | 08:12 AM
arctic y block
Ya that's what I thought. Could well be 428. Said they done a lot of mach. work to the block. said he used a 427 or 428 crank and pistons. but cold'nt remember for sure. Said that he was supprized it was still running as it would keep brakeing the hi lift cams in two at the back of the block. I put a stock 390 cam in it and have had no problems. I will move it up to the shop in the next day or so and get the numbers off the block and heads.
Thanks bear
Old Nov 6, 2006 | 01:30 AM
Shortbed's Avatar
Shortbed
the guy was probably right just going by cubic inches, but didn't know much about FE's
427 - 4.23 bore 3.78 stroke = 425 cubic inches
428 - 4.13 bore 3.98 stroke = 427 cubic inches
Old Nov 6, 2006 | 05:25 AM
baddad457's Avatar
baddad457
With the stroker cranks out there now, anything is possible. Cranks with up to around a 4.25" arm would give a 390 bore, more than 427 inches.
dadstan76
Aug 15, 2009 05:31 PM
tylstruck
Feb 2, 2008 04:36 PM
jazzy66
Feb 28, 2005 07:20 PM
ilikefordtrucks
Sep 15, 2004 04:23 PM
anotherF150
43
Nov 30, 2002 07:25 AM
