R10F overdrive
Old Sep 23, 2002 | 09:52 AM
lbyblock's Avatar
lbyblock
Post R10F overdrive
I just acquired a 3 speed trans with overdrive. It's a T86E-IN tranny with an R10F-1B overdrive. The solenoid is 12 volt so I assume it's post ‘56. The trans came out of a car (it has the tail piece mount) and I want to put it in my 292 driven ‘54 F100. Does anyone know what this trans was in originally (then I could get the shop manual for the od info)? Also, can I put the overdrive on my truck 3 speed (so I can use the big clutch instead of the car clutch)? If not, how much trouble is it to switch the input shaft's on the transmission? Finally, does anyone have a source for parts/service for these od's? The overdrive mainshaft is bent (maybe from being stood on end) and will need to be straightened or replaced.
Larry
Old Sep 23, 2002 | 11:38 AM
hamz52's Avatar
hamz52
R10F overdrive
Daddyo's garage
32
Sep 26, 2013 05:58 PM
oneill
Jun 21, 2011 01:25 PM
ken_r_mer
Sep 11, 2010 07:03 AM
Prozon
Offroad & 4x4
Aug 12, 2008 10:35 PM
