2002 4.2 rough idle
Old Nov 4, 2006 | 03:30 PM
20024.2V-6's Avatar
20024.2V-6
2002 4.2 rough idle
well guys when my truck is cold and after the initial start up couple of min later when i let it idle it sounds rough but its not missing? i have new plugs and a k&n filter and just replaced the fuel filter... also after a day or 2 of sitting its a little hard to start and does miss a couple of times before evening out.
anyone got any ideas on what to replace to help this little prob? any help would be apreciated thanks
Old Nov 4, 2006 | 07:00 PM
BrianA's Avatar
BrianA
How many miles on your truck?
Have you checked the coolant level to be certain you are not losing any coolant via a leaking lower intake manifold gasket?
You mentioned new plugs. What brand?
Did it miss prior to installing new plugs?
Did you install new plug wires?
If you are not losing any coolant, I'd suspect plug wires if you don't have new ones.
You describe a common complaint from folks who need new plugs and wires.
Old Nov 6, 2006 | 04:44 PM
20024.2V-6's Avatar
20024.2V-6
i got about 77,000 on it and i suspected new plug wires, i was just woundering if it was something els and no i dont have any coolent leakage? i thought that they resolved that problom by 2000-2001? o yeah and the plugs were motorcraft i bealive thanks for the help
Old Nov 7, 2006 | 01:26 AM
wi_bear's Avatar
wi_bear
yeah
I had a rebuilt that was a Ford. Had 73k on the truck and it seized. Got another 100k after that Ford rebuilt and motor seized again. I know I put it through hell and that is why it went through two engines but I did expect more from something that only towed a little. Mainly trail driving.
What do you do with your truck? If it involves towing just cut your losses and get something bigger!
Don't get me wrong I love my dead truck but you have to assess what you are doing. The 4.2 is good for a "light duty" truck but that is all! I don't want to hear anything else.
If you have questions pm me I'd be happy to help.
I went bigger with tires and that was all. If you need a truck for something more than civillian duties get a V8 or F-250+ that is the bottom line
Old Nov 7, 2006 | 04:25 PM
20024.2V-6's Avatar
20024.2V-6
yeah thats true bigger is better but the only thing my truck tows is MAYBE a bass boat every once in a wile other than that theres nothin in it....i got it for the gas mileage trying to be smart but i got to talking to a ford mechanic and he told me the 4.6 gets the same but o well im happy with it....for now
Old Dec 10, 2006 | 05:07 PM
20024.2V-6's Avatar
20024.2V-6
what plug wire brand should i go with? lemme know im gonna be replaceing them soon!!
Old Dec 11, 2006 | 09:40 AM
BrianA's Avatar
BrianA
Don't get talked into disliking your truck.
If it is reliable and works for you and your needs, it's a good truck.
242,000 miles between 2 F150s w/ 4.2 and I'm perfectly happy.
Regarding plug wires: I use Motorcraft.
Too many reports of problems with others.
Triple777
Dec 5, 2014 12:02 PM
bgibbons60
2004 - 2008 F150
Jun 5, 2014 07:09 AM
MentalState
Apr 10, 2014 11:34 AM
findingidaho
Sep 8, 2013 09:54 PM
