Sponsored by: Real Truck
Slight idle issue help please
Old Dec 5, 2014 | 09:18 AM
Triple777's Avatar
Triple777
I have a 99 F350 with a V10. I just replaced all the spark plugs and a bad coil which solved the very bad misfire I had going on. I also just changed the fuel pump and fuel filter.
When I start the truck, it idles just fine, nice and smooth. After sitting there for a short bit, maybe a couple minutes, it starts to idle rough, not so rough that it's about to shut off, just a little rough. This lasts maybe a minute and then goes back to nice and smooth and stays that way.
I've thought maybe the EGR valve or Idle air control valve but I'm not sure if I'm way off or sort of close. Wanted to see if anyone on here knows what the issue is. Thanks for any help!
Old Dec 5, 2014 | 12:02 PM
Triple777's Avatar
Triple777
Please delete this thread, I moved it down to the V10 area. I tried to delete it myself but I must be having an off day cause I can't figure it out.
SoCalMobile
Modular V10 (6.8l)
Jan 13, 2010 12:08 AM
ford9991
Modular V10 (6.8l)
27
Sep 22, 2007 02:13 PM
flier
Modular V10 (6.8l)
Jul 16, 2003 10:21 AM
