He guys I am new to this site just today and love it already!! I am having a problem with the brakes on my 97 F-250 crew cab. When I pulled in the drive this morning I noticed the brake pedal felt hard and I had to push it extrmely hard to get it to stop. Aupon further investigation I found that if I drive a few minutes the brake light will go out and the brakes are fine for a few seconds. If I pump the brakes the light will come back on and the pedal gets hard again. I am thinking a vaccum pump because I also notice a knock under the hood and I hope it is just the pump. Also how much vac pressure should the pump make at idle so I can test it. If anyone can help I would appreciate it very much.
It's the vaccum pump. Mine acted the same way a month ago. New pump and the brakes are better than before!! Took about an hour. bought mine from Autozone. If you don't fix it soon it will belly up on you when you can least afford it.
Search this fourm for "vaccum pump" and you will get a lot of helpful hints on how to install it.
u should have 18 inches of vac at idle at the pump minimum. i had to install a new one bout a month ago too, fairly easy just a pain gettin at one of the bolts and u need to swap the pulley if the new doesnt come with one on it. you will need a special puller to remove and install the pulley. new pump was right around 25 inches at idle.
Thanks alot!!!This web site is graeat. I am very good with gas motors, but have very little experience with diesel motors. Thanks so much for the help. I am headed to Oreillys I guess.
I don't know about O'Reilly But a lot of parts stores in our area will loan you the puller or just bring the old pump & they will swap the pulley right there.
Yeah I dont know why so much stuff on these trucks has to be layered like that.
Makes me wonder what the engineers were smoking when they were designing them.
I just got the new pump installed and it worked great. I saw that i could not get the bolts out without removing the pully first and amazingly I remembered to put them in the holes first. I could not get any of the bolts out until the pully was removed. All in all a pretty easy job and seems to be working great. Now for the lift (fuel) pump. Looks to be a real pain. Does anyone know if I have to replace the cali pump with the same thing or can I use a standard pump. The cali pump has a big disc on to of it that says bosch on it I believe. If anyone has done a pump like this let me know how it went. Thanks again for all the hlep.
The turbo MUST come off when replacing a cali pump, I feel your pain. I'm pretty sure the 2 are not interchangable. Maybe replacing fuel line going to the heads will allow a non-cali pump to be installed.
