Hard shifting in cold
Old Nov 6, 2006 | 04:53 PM
waterboy_fishing's Avatar
waterboy_fishing
So, can we assume this is an engineering flaw since so many faulty injectors are being produced? I have seen new trucks react this way in temperatures near 30 degrees.
Old Nov 6, 2006 | 08:54 PM
BowTieHatr's Avatar
BowTieHatr
Originally Posted by raptor131
so it should sound and shift the same warm or cold? no matter what? I thought it was the "cold strategy" of the pcm . I thought it was normal. I just can see taking it in and they take my $100 and tell me everything is fine.
let me explaine. the pcm incorporates boost into the shifting strategy in these trucks, and the transmision shifts into a different third or fourth gear. so there will be a small difference being the cold strategy. now when the injectors are still sticking while your trying to drive, then it will kill boost and change the shift pattern due to power loss. plain and simple, you should be able to hop in and go when your truck is cold and only a minor difference should be noticed. now if there is a major difference or at any time anyone is not satisfied with the performance cold, then you need to take it in. i have experienced so many cold start issues and lack of power cold i was quick to point at the injectors. also guys to let yall know the new tsb about injectors wont cost anything as long as its done under 36/36.
Old Nov 6, 2006 | 08:59 PM
BowTieHatr's Avatar
BowTieHatr
it is more like a bad design. i feel like the main reason is that the injector coils are not strong enough. the 73s were 115 volts where these on the 60 are 48. therefore the oil is sticky and causes the injectors to stick.
Old Nov 6, 2006 | 09:32 PM
blackhat620's Avatar
blackhat620
Originally Posted by fireman_19
Hey Guys! This is my first winter with my truck, it's a 05 350 cc fx4 and when I start it in the mornings it feels and sound just awful. I try to let it warm up a little before I leave for work but I think it may wake up the neighborhood. It shifts really hard and pushes the rpms up before it shifts. Once its warm it does fine. Takes about 5 or 6 miles. Is this normal? Temps right now are low 40's at night. Thanks!
raptor131, waterboy_fishing,
Also gentlemen you will notice in the original post that his temps are in the low 40's and it does this for 5-6 miles.
As BTH and CandaGuy both said in the first couple of posts, this is not correct, it can be injectors or transmission problem.
There are TSB's out on this:
06-2-13
http://www.ford-trucks.com/tsb/fullt...hp?tsb=06-2-13
And as BTH stated if it is within the 3/36 warranty no charge.
So give the techs a break and let them answer fireman_19's question and solve his problem (and possibly yours). If you are past your 3/36 warranty and into the 100K warranty, and you are happy with how your truck runs then don't take it into your dealer. Choice is yours to make.
Hope this helps
Old Nov 6, 2006 | 09:51 PM
Jocaren's Avatar
Jocaren
so if i get in my truck in the morning and the temp guage is still stuck at the bottom and i put the pedal to the floor it will react just like it was warm??? MAn if thats the case my truck is completely F#&@#%
Old Nov 6, 2006 | 11:15 PM
TexanClint's Avatar
TexanClint
Mine does same thing. Hard shifts when cold, shifts perfectly smooth when a little warm.
Old Nov 6, 2006 | 11:39 PM
chili7's Avatar
chili7
So if I understand, and I may not, at 40F this could be an problem, but at 22F, it probably is not. I always understood that cold affects any engine, gas or diesel, but it appears in the case of waterboy_fishing there should be no affect on the tranny at those temps. Am I OK so far?
Old Nov 7, 2006 | 12:16 AM
blackhat620
chili7,
If you click on the link to the TSB in my post above, you will see that the testing is done with the engine ECT between 20F - 50F, so yes you could have an injector issue at 22F.
Yes cold effects both gas and diesel engines, But comparing the 6.0 PSD to your old gasser is not an effective comparison, since the engines and transmissions of these vehicles are designed different and of different age.
So do you have a problem with your 6.0 PSD when it is 22F outside, maybe. Read the TSB and see what you think is the best course of action for you to take with your truck.
Hope this helps
Old Nov 7, 2006 | 07:22 AM
raptor131's Avatar
raptor131
I appreciate your responses. I don't wanna come across as rude or questioning your knowledge ,I just wanna be clear. as i may have a problem i never thought was a problem. but alot of this maybe left to interpretation as hard shifting to me may not be hard shifting to another. you have cleared things up for me. but this looks to be a hot topic. as alot of people like me are saying .......whoa! mine does that!
Old Nov 7, 2006 | 08:49 AM
BowTieHatr's Avatar
BowTieHatr
no offense taking. sometimes it is hard to say normal-not normal through a key board.
Old Nov 7, 2006 | 10:42 AM
waterboy_fishing
Well, I just got off the phone talking to my local service rep and he said this is not normal and I should have the truck looked at. Apparently Ford has come out with a better injector if that turns out to be the problem. This has been a great, and at times temperamental, discussion but I'm glad you guys are hear or I would have never known about it.
Old Nov 7, 2006 | 11:00 AM
ag-ford-4x4's Avatar
ag-ford-4x4
Hard shifting when cold...i vote NORMAL as well.
If the temps get to even 55 degs and the truck has been sitting for 8 hours or so, mine shifts hard for a few miles. I wouldn't worry about it. You start taking it to ford "techs" and they will find all kinds of 'Problems'.
Easy does it, drive it and leave it be.
Old Nov 7, 2006 | 11:28 AM
  #28
blackhat620
I am not trying to start an argument with you, and it is your truck and you can do with it as you please. But if you are having these issues at 55F then your truck is probably not operating normally.
If you are happy with how your truck runs, you don't have to take it your favorite Ford tech, just beware that this is Not Normal operation at 55F temperatures.
Also there are alot of Good Certified Ford diesel techs out there. If you don't have a good one at your local dealer, then i would find a new service department with a qualified and knowledgeable diesel tech.
Hope this helps
Old Nov 7, 2006 | 03:18 PM
  #29
fireman_19's Avatar
fireman_19
I appreciate all this duscussion about this issue. I had no idea this would get such a response. I decided to let it warm up an extra couple of minutes and the "problem" seems to ease. I have 77,000 miles so taking it to the local dealer is not an option. No check engine light and it runs smooth when warm so I'll keep going. thanks!
Old Nov 7, 2006 | 04:45 PM
  #30
blackhat620
[QUOTE=fireman_19]I have 77,000 miles so taking it to the local dealer is not an option.[QUOTE]
You are aware that the engine is warrantied for 100k miles and any warranty repairs on the engine would only cost you the $100 deductible.
Hope this helps
