chrome at home
Old Nov 3, 2006 | 11:58 PM
thefarelaneman's Avatar
thefarelaneman
chrome at home
I was thinking about buying a do it yourself chrome plating kit to do the small pieces on my fairlane restoration. Anyone tried it and advice would be appreciated,
Old Nov 5, 2006 | 11:51 AM
Unfairlane62's Avatar
Unfairlane62
Hi I'm restoring a fairlane as well (62/63) and also need a lot of the chrome doing, I'd never heard of a diy kit, where can you get them from and how much is it? sounds quite good but I'll see what people say about them. rick
Old Nov 5, 2006 | 12:18 PM
furball69's Avatar
furball69
Sounds too good to be true. Any links to the kit, online?
Old Nov 5, 2006 | 09:42 PM
thefarelaneman
"GOOGLE" chrome plating kits.........Alot to pick from and varity of prices
Old Nov 5, 2006 | 11:32 PM
furball69's Avatar
furball69
Interesting. So you're looking at something like this?: http://www.caswellplating.com/kits/triple.htm
When it comes down to it, there is nothing to the dipping portion of the chrome restoration process; 85% of the work is done in the prep and polishing process. YOu can take an old hunk of metal and chrome it and it will look like an old hunk of metal, with chrome on it. If it's not smooth as a baby's butt when it goes into the tank, it ain't going ot look good.
Old Nov 6, 2006 | 12:38 PM
thefarelaneman
Talking
I dont plan on doin it sloppy. Same thing goes for baking cakes, If you just throw a few eggs and sugar into a shoe box and then pop it into the oven dont exspect no french pastry,,,,,,,,LOL
Old Nov 6, 2006 | 12:55 PM
furball69's Avatar
furball69
I realize I could have worded that better but what I was trying to say is that you'll have to be more adept at polishing metal than anything else. Those kits look pretty good, as long as you follow the instructions and keep the solution temperatures in spec, make sure everything is clean and don't cross-contaminate your solutions, it should work fine.
Old Nov 6, 2006 | 10:33 PM
thefarelaneman
home chrome
Fur. No you told it like it is.From what Ive read having the parts ready is most of the work.In fact I read where you cant just re-chrome over old chrome, It has to be removed and then a first coat of nickle has to be applied then the chrome. Not a fast process. Thanks for you advice
Old Nov 6, 2006 | 11:16 PM
furball69's Avatar
furball69
Yes, the chrome does have to be removed, I was going to ask if the kit you were looking at had chrome stripper or not, you'll need it. There's a few ways to do it: manually, by sanding/grinding or sandblasting - the hardest and least preferred method. Electrically, in a hot caustic solution, like reverse plating - the preferred method and in an acid bath - effective, but be careful what you put in there, that acid will eat aluminum and pot metal.
High quality 'show' chrome uses a triple plate; copper, nickel and then chrome. Sometimes the copper is put on thick and then the piece is buffed to a mirror finish and then put through the three stages again for about the best finish you can get.
