Can someone decipher my VIN please?
Old Nov 3, 2006 | 03:32 PM
YaddaYadda's Avatar
YaddaYadda
New kid on the block. I typed "VIN decoder" in the search tab but only unanswered threads showed up.
I just bought a 2000 Ranger XLT and have the VIN but the truck is still at the dealer getting the "check engine" light diagnosed and fixing the power steering which is stiff and heavy.
Anyhow the VIN is 1FTZR15V1YTA16032. Could someone decode it for me OR direct me to a site where I could ferret it out.
I have the CarFax VIN check sheet.
Many thanks
Old Nov 3, 2006 | 04:57 PM
lgaltuna's Avatar
lgaltuna
1st digit = country of origin 1 = USA 2= Canada
2nd digit = manufacturer F = Ford
3rd digit = type of vehicle T = truck
4th digit = gross weight
5th digit = model R = Ranger
6th & 7th digits identify chassis and body type
8th digit identifies the engine
9th digit is a check didgit
10th digit identifies the model year
11th digit is the assembly plant
Digits 12 thru 17 make up the sequential serial and warranty number. Digit 12 uses the letter A until the production or sequence of 99,000 units (digits 13 thru 17) then A becomes B for the next production sequence of vehicles. Your vehicle was the 16,032 built in the first production run that year.
Old Nov 3, 2006 | 08:35 PM
YaddaYadda's Avatar
YaddaYadda
Thank you sir
Old Nov 3, 2006 | 09:25 PM
Tiggie's Avatar
Tiggie
Google "Ford Fleet Vin Decoder" and you should find the site you need, should be the very first listed.
Old Nov 3, 2006 | 09:33 PM
lgaltuna's Avatar
lgaltuna
VIN Results New Search
VIN: 1FTZR15V1YTA16032
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: USA
Make: Ford
Body Style: Pickup
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: Z
Brake System: HYDRAULIC
GVWR Class: Class D
GVWR Range: 5,001 - 6,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: R15
Vehicle Line: Ranger
Series: XL
Body Type: SUPER
Vehicle Type: Truck/SUV
Engine Type - 8th Position
VIN Code: V
Engine: 3.0 L
Cylinders: 6
Fuel: Gasoline
Model Year - 10th Position
VIN Code: Y
Model Year: 2000
Assembly Plant - 11th Position
VIN Code: T
Assembly Plant: EDISON: EDISON, NJ
Production Sequence Number - 12th - 17th
VIN Code: A16032
Prod Sequence Number A16032
