Fuel Injectors in E350 Van
Old Nov 2, 2006 | 03:59 PM
johnguc's Avatar
johnguc
Anyone here ever change fuel injectors in a van?
Ive got 7 of them out but I cant get get number 3 on the passenger side out.
There is not enough clearance between the body and the head to get the injector out far enough to clear the bore.
I tried denting the body with a long pipe for clearance and now Ive got a dent in my head to show for it.
Could I maybe pull the passenger side engine mount bolt to gain some clearance?
Would this actually gain me some room? It looks like it could make it worse.
Im also worried I might break a line loose somewhere.
Could this happen?
Also anyone ever use the ford injector replacement tool?
I cant really see having enough room to hit the inside ones with a rubber mallet.
How about gently pressing them in on the top of the injector with a crowbar or piece of wood?
Bad idea?
Old Nov 2, 2006 | 04:22 PM
Cuda_jim's Avatar
Cuda_jim
I've not done this but here is what the repair manual says. Hopefully ther may be someone else that has a short cut.
If removing injector 3 or 5, perform the following:
Raise vehicle.
Remove LH engine mount-to-engine bolts.
Raise engine.
Remove LH engine mount-to-crossmember nuts.
Remove LH engine mount.
Lower engine until oil pain is resting on crossmember.
Remove RH body mount-to-frame bolts No. 1 and No. 2.
Lower vehicle.
Remove RH body mount-to-frame bolt No.3. The bolt is located in passenger compartment under carpeting.
Raise body of vehicle on right side until fuel injectors are sufficiently clear of obstructions and can be removed without damaging the O-rings.
Old Nov 2, 2006 | 05:12 PM
johnguc's Avatar
johnguc
OMIGOD!!!
All that for 1 injector.
I'm really getting sick of working on this thing
Everything is a major fight.
Is that a cut and paste that says LH?
odd I would think RH or both.
My GF wants to set it on fire Im starting to get tempted about now to let her do it.
Old Nov 2, 2006 | 05:57 PM
trike1946's Avatar
trike1946
We who are blessed with the E series have many more problems than the F series. No only is it harder to get to everything, the vans have less power because of the heat build up in the engine compartment. I moved the batteries to the back and changed the intake for some extra room, but the injectors are another thing. Short of cutting the fire wall apart, I don't think there are any short cuts.
Old Nov 3, 2006 | 05:48 AM
Cuda_jim's Avatar
Cuda_jim
Originally Posted by johnguc
OMIGOD!!!
Yep, cut and paste from the manual. I feel your pain, I absolutley hate working on these vans. I take care of 2 regularly, 1-triton the other is a 460.
The instructions are for #3 & 5 injectors.....LH for #5 and RH for #3.
You GF may have the right idea
Old Nov 3, 2006 | 07:29 AM
Ilikebigtrucks's Avatar
Ilikebigtrucks
I don't think there have been any rearwheel drive vans that were much fun to work on. It's just not a great idea. GM's offerings were no better to work on as far as I can tell. For that matter - try changing the sparkplugs on a LT1 Camaro.
Old Nov 3, 2006 | 11:08 AM
MPlayer's Avatar
MPlayer
Don't get to frustrated. Have a beer and think about it and then try again. I know it is easy for me to say I have a F series but we have to fight the back valve cover bolts.
Mark
Old Nov 3, 2006 | 12:05 PM
E4X4's Avatar
E4X4
Talking
Just remove the coil off of the injector.
Bill
Old Nov 3, 2006 | 01:54 PM
MPlayer's Avatar
MPlayer
Talking
I hadn't thought of that. That is a good idea. Yeah, what he said.
Old Nov 3, 2006 | 02:44 PM
ken1mod's Avatar
ken1mod
The gm rear wheel vans are super easy to work on. I used to do in-frame rebuilds on the small blocks with great ease. No need to loosen mounts to drop oil pan. heads come off from inside van. really really easy. I wish more attention was being paid to serviceability. My nephew has an old mercedes that you have to remove a crossmember to remove the oil filter. unbelievable. I guess we don't look at these things in the showroom. even the best vehicles need work now and then.
Ken
Old Nov 3, 2006 | 02:53 PM
E4X4's Avatar
E4X4
Also I used a longer bolt with a nut on the inj to remove and install the inj in the head.
BTW Mplayer--How do you fillout sig.
Bill
Old Nov 3, 2006 | 03:36 PM
MPlayer's Avatar
MPlayer
Thumbs up
Click on your user name then click on view public profile then you can go in and put all your info including your sig in.
Old Nov 3, 2006 | 04:24 PM
E4X4's Avatar
E4X4
Thumbs down
Sig no workie!!! Seems you have to join Club FTE to get a sig.
Bill-----Dont mean to highjack
Old Nov 3, 2006 | 04:31 PM
johnguc's Avatar
johnguc
E4X4
You posted your first post 1/2 hour after I went out to the garage.
To bad I didnt stall going out there/
Now Ive got 2 broken body mount bolts to fix. F me.
I did figure out pulling the coil myself 2 1/2 hrs later.
Old Nov 3, 2006 | 04:42 PM
E4X4's Avatar
E4X4
Sometimes you have to say WTF.
If their was a list of things easy to repair in a PSD VAN it would be a short one.
Bill
