Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Escape A/c Knobs...
Old Nov 2, 2006 | 01:29 PM
j_alvarez's Avatar
j_alvarez
Escape A/c *****...
Hello,
New here and was wondering if anyone knew where I could get a couple of 2002 Ford Espcape *****, for the A/c control and temp control? Mine stripped on the inside and will not turn the control anymore. If anyone has any info, I would really appreciate it. Thanks and have a good day!
Joe
Old Nov 3, 2006 | 09:55 AM
jpark's Avatar
jpark
Originally Posted by j_alvarez
Hello,
Joe
Here's an eBay auction for the entire assembly for only $39:
http://cgi.ebay.com/ebaymotors/Tempe...QQcmdZViewItem
Old Nov 5, 2006 | 08:43 AM
Pejeeper's Avatar
Pejeeper
Dealer item only. Kinda pricey, but are built better than original. Had to replace them too, ,crappy thing to spend $$ on but ya need heat in the winter!
Old Nov 5, 2006 | 08:58 AM
ove1's Avatar
ove1
If the **** ferrule is just cracked and not broken off, you could try glueing a 3/8" compression fitting (the kind used with copper or plastic water line to join it to a copper compression fitting) on the ferrule to repair it. I reinforced all of mine this way and have yet to break one.
Old Nov 19, 2006 | 11:53 AM
jzobel's Avatar
jzobel
I had the same thing happen with my '01 Esc XLT V6 4WD (except it was the fan and function *****). Took it to the dealer for regular service & had replacements installed while it was in. Not happy with the new *****, as they don't sit flush with the panel the way the temperature- and original ***** did.
Old Aug 24, 2010 | 09:05 PM
18923's Avatar
18923
cheap fix
I was able to fix all three of my ***** by applying some super glue to the cracks and then re-enforcing with two applications of heat shrink tube. It appears to hold well, but only time will tell.
Old Mar 11, 2011 | 12:17 AM
burley68's Avatar
burley68
Had the same problem on the wife's 03. She would crank the fan **** so fast she ended up breaking it. I fixed mine (and reinforced the other two) by using heat shrink tubing & a zip tie on the back side. I also moved the fan **** to a lesser-used function (heat control) to extend the life of it. It's been at least 5-6 years now and none of them have failed.
ppdl23
Dec 5, 2014 08:17 AM
action_deez
Nov 14, 2014 07:08 PM
Michael Moshier
2004 - 2008 F150
May 15, 2012 12:18 PM
gungho351
Nov 30, 2010 10:26 PM
