25 Mpg
Old Nov 4, 2006 | 03:20 PM
jimlj's Avatar
jimlj
I hope your right in your calculations. That would be great!!!
My experiance started out having me think my truck was getting around 16-18 mpg. Turns out that the valve that switches tanks was drawing fuel from both tanks, and I was only filling the one I thought I was using. I ran "out" of gas with over 3/4 tank showing. It took several hours for me to figure out that one tank was empty. A couple gallons of gas in that tank solved the problem, but my fuel economy economy went from about 17 mpg to 10.
Old Nov 5, 2006 | 07:54 AM
460's Avatar
460
Originally Posted by brentleedragon
I am 100% positive its correct because i write my miles down everytime I fill her up
Do you figure your MPG at every fill up? Do you consistantly get 25 MPG?
Old Nov 5, 2006 | 11:36 AM
77bigblock's Avatar
77bigblock
I got 22 mpg with my 78 F100 with a 300 consistently on the highway. I suppose if you drive like a grandma and it is perfectly tuned, this would be possible.
Old Nov 6, 2006 | 02:25 PM
ford141's Avatar
ford141
Not to Pirate a thread, but, ford141: Did you re gear axels or recalibrate your speedo after the 35s install?? If not than your getting better milage than you think. And you may be in for a fat speeding ticket because your speedo is way off.
No, I have not regeared after installing the 35's yet, but I used the Edge Evolution tuner to recalibrate the speedo. Gears are coming, tho, going to 4.56's in the near future to safe some wear on the tranny while towing.
Back to the regularly scheduled thread---
Old Nov 6, 2006 | 09:00 PM
brentleedragon's Avatar
brentleedragon
25 is my highest, when i first got the truck it was 9-12 and then i got it up to about 16-18, and then 18-20 and this is my highest, I am not sure if it will be an average, I actually havnt driven the truck in a bit so hope fully it will be 20-25 which would be cool
Old Nov 6, 2006 | 11:10 PM
old ford nut's Avatar
old ford nut
my 77f250 2wd 400c6 gets a whopping 9mpg but I like the truck so I'm going 12valve cummins
Old Nov 7, 2006 | 09:35 AM
76 F-150 390FE's Avatar
76 F-150 390FE
my 76 4x4 390 C6 gets a whole 5mpg if i ever see 15 out of it it will make my life and its my daily driver.
Old Nov 7, 2006 | 10:57 AM
tcbofade's Avatar
tcbofade
25 mpg?? I'm getting 10 on a good day. I'm jealous.
Old Nov 7, 2006 | 12:26 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
What changes have you made to this truck to go from 9-12 mpg to 25 mpg? I dont think the truck would do this on its own.
Old Nov 7, 2006 | 03:48 PM
Mil1ion's Avatar
Mil1ion
Because there are so many variables to consider regarding fuel economy it is difficult to compare against other vehicles and drivers.
Old Nov 7, 2006 | 05:28 PM
kilog55's Avatar
kilog55
perhaps the tires are too small like you said and it is reading more miles then driven by turing more rpms at the wheels?
Old Nov 8, 2006 | 06:39 AM
cowboyty's Avatar
cowboyty
That would be great to get 25mpg, my 78 400 2bbl 4spd gets 8 to 9 mpg average per tank. I have been driving it to work while my 99 is in body shop. Now I am tired of stopping at gas station everyday to fill it up. One tank behind the axle, full of gas and guage reads either full or 3/4, but when it gets close to E i am filling up again. Also I am running 87 octane unleaded.
Old Nov 8, 2006 | 02:18 PM
  #28
Mil1ion's Avatar
Mil1ion
In the first 4 years of my truck.
Because of :
The way I drive
I had inflated the tires properly
loaded truck with minimal weight (but still had 3 pasengers)
On trip to BC, I averaged 24 mpg with my 400 C6 2.75's
This was in mountainous territory where speed always has to be altered, with many 6% & 7% grades ,drivling mainly at night.
Old Nov 8, 2006 | 08:37 PM
  #29
T.R.Bauer's Avatar
T.R.Bauer
All I have to say is wow.....and who knew that pigs could fly! I have never known or even heard of anyone getting over 20 mpg with one of these full size, emission laden, un-aerodynamic bricks. PS... please don't talk to loud, I don't want this dream to end.
Old Nov 8, 2006 | 08:57 PM
  #30
MBBFord's Avatar
MBBFord
I have gotten alittle over 20 mpg before in my 77 F-100, but that's driveing like a grandpa on the interstate at about 60-65mph, while accelerating very slowly, slowing down on over passes and the rest is flat road, and the truck as a perfect engine with alittle over 10K miles(new engine), a very smooth tranny, and 3.50 gears and 29" tires.
So basically with a perfectly tuned truck and an extreamly mpg cautious driveing style, it barley got alittle over 20 at cruseing speed.
