Squeaking in Front-end
Old Nov 2, 2006 | 11:47 AM
Rob04's Avatar
Rob04
Hi,
After I noticed I posted this in the wrong forum, I will try again here.
I have a 2001 f-350 4X4 with manual hubs. The front differential has the proper amount of oil in it, as does the transfer case.
My problem is when I lock the hubs in, I hear a squeaking (squealing) sound from the front axle area while driving. If I stop and unlock the hubs the squeaking will continue until the front drive shaft stops turning. The sound is NOT like a bearing turning in its race (ringy-dingy sound). It is definitely a squeak and it only appears when the hubs are turned in. The squeak comes and goes as I drive along, for example, if I hit a real slippery spot in the road and all tires are spinning in the mud, the squeak goes away for a while.
I think my problem is a bearing at either end of the front driveshaft, but I have no experience with R&R'ing the front drive shaft. Could the differential pinion seals possibly cause this type of squeaking? Any ideas you guys have would sure be appreciated. thanks.
Rob
Old Nov 3, 2006 | 11:30 AM
kbeefy's Avatar
kbeefy
if it does it all the time when your hubs are locked (2 or 4wd) then it's hub related, probably a dry or delaminated outer axle/hub seal. Try driving it in 4wd w/ hubs unlocked, that should pinpoint what area it's in. Give your d-line and axle u-joint a good shake, make sure you don 't have some dry bearings in there.
Old Nov 3, 2006 | 02:57 PM
Rob04's Avatar
Rob04
Thank you for your suggestions. I will do that this weekend.
Rob
