kd cable
Old Nov 1, 2006 | 11:57 PM
rogmale's Avatar
rogmale
kd cable
Just about ready to install an edelbrock 1405 on my 66 cs, installed a 360 this year with com behind it. I think the lokar kd cable for fmx will fit. But is it actually worth doing, or simply stay with the original rod?
Old Nov 2, 2006 | 03:06 AM
airharley's Avatar
airharley
Either way the kickdown will work. One just looks better then the other. If you are asking which one makes it easier to adjust the kickdown point. Then I would definately use the Lokar since you don't have to bend any rods or crawl under the truck. Just loosen a jamnut and move the cable end as needed.
Old Nov 6, 2006 | 09:53 PM
rogmale's Avatar
rogmale
Thanks for the input. will stick with the rod for now, go to the cable when $ allow.
