Rear Main Seal
Old Nov 1, 2006 | 06:05 PM
coldnorthpole's Avatar
coldnorthpole
Rear Main Seal
I just noticed today that my rear main seal appears to be bad.
There is fluid coming down over the break housing. Not alot, but enough to notice.
What will the parts typically run for a repair like this?
Thanks!
Old Nov 1, 2006 | 06:14 PM
1982fordf100's Avatar
1982fordf100
A rear main seal is around $15 or $20. I used one from felpro when I did my rebuild. My 300 had the one piece seal as I believe all 300's use this type. In order to change it the transmission needs to be removed. Make sure its not your oil pan gasket going bad. The pan gasket does go directly over the rear main bearing cap so that could be the source of the leak. If your going to have this done by someone else I would imagine the labor alone would be a few hundred dollars just for the work involved of removing the transmission. Also is the leaking running down the front of the bellhousing block plate? Or is it running down the back of the bellhousing?
Ford SD
Mar 21, 2016 08:02 PM
hanabi
Jul 21, 2008 05:53 PM
jdsdidit
Aug 7, 2007 07:24 PM
mxtrp
Aug 25, 2005 06:57 PM
DT 466Man
Apr 29, 2005 10:41 PM
