cel light code po175
Old Oct 29, 2006 | 01:05 PM
mdk1506's Avatar
mdk1506
2003 ford explorer
Old Nov 5, 2006 | 06:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
BUMPED
Let's see if we can help you out here!
Old Nov 6, 2006 | 04:29 PM
mountaineer man's Avatar
mountaineer man
here is what i can tell you
P0175 - System to Rich (Bank 2)
The Adaptive Fuel Strategy continuously monitors the fuel delivery hardware. The test fails when the adaptive fuel tables reach a lean calibrated limit
check the fallowing systems
For lean and rich Strategy continuously DTCs:
<O</O
Fuel system Excessive fuel pressure. Leaking/contaminated fuel injectors. Leaking fuel pressure regulator. Low fuel pressure or running out of fuel. Vapor recovery system. Induction system: - Air leaks after the MAF.- Vacuum Leaks. - PCV system. - Improperly seated engine oil dipstick. EGR system: - Leaking gasket. - Stuck EGR valve. - Leaking diaphragm or EVR. Base Engine: Oil overfill Cam timing. - Cylinder compression. - Exhaust leaks before or near the HO2Ss.<O></O>
Joel
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
Roachfood
Mar 11, 2002 10:21 PM
