Electric Brake Install
Old Nov 1, 2006 | 11:26 AM
Chilli's Avatar
Chilli
Hello,
This is my first post on this forum so I am grtateful for any help.
I am going to install an electric brake controller in my 1999 F-350 Crew cab dually.
It appears that it had a controller installed before I bought it.
What color wires are in the factory harness to attach to the controller?
Are they located by the electical distribution box under the hood? The truck has a seven pin harness in the bed and in the bumper.
Thanks Chilli
Old Nov 1, 2006 | 11:54 AM
JGRNAUT_7.3L's Avatar
JGRNAUT_7.3L
Well not absoluty sure about the 99 but in my 02 there is an adaptor harness that you wire the controller too and then it just plugs in under the dash above the gas pedal. I am sure somone else will chime in with a definitive answer.
Old Nov 1, 2006 | 11:58 AM
empiretc's Avatar
empiretc
There should be a plug like JGRNAUT said. It would be behind the dash where the 4x4 switch would be. I had a little trouble finding mine since it had never been used.
Old Nov 1, 2006 | 12:16 PM
catman52987's Avatar
catman52987
I have a 99, and when I put the brake controller in, you you had to remove the plate under the steering wheel. If you look on the right hand side you will see a hole that leads to a cavity behind the radio. The connector is tied up right through the hole and is in plain view.
Old Nov 1, 2006 | 12:28 PM
Chilli's Avatar
Chilli
Is it a small round plug about 9/16 " dia?
