460 in an Excursion
Old Nov 1, 2006 | 08:11 AM
MattsExcursion's Avatar
MattsExcursion
460 in an Excursion
Hi all,
has anyone ever put a 460 big block in an Excursion or the new body style super duty?
Old Nov 1, 2006 | 09:10 AM
Downriver Thunder's Avatar
Downriver Thunder
I have a question, why would you want to?
Old Nov 1, 2006 | 02:22 PM
MattsExcursion
#1) Im not saying i am doing that for sure but I am thinking about it #2)for more power! #3) you can do way more with a 460 big block than with V10 or a diesel
Old Nov 1, 2006 | 02:25 PM
Downriver Thunder
Isn't that motor like really outdated? Is there anything, powerwise, available for that motor anymore? Not sure when they quit using it, I remember them being in the old 1 mile long Lincoln Continentals. I think my Dad had a 78 LTD with one too. Came with a 351 Cleveland and he swapped out.
Old Nov 1, 2006 | 02:41 PM
MattsExcursion
Ford put these engines in thier pickups... I had one in my 97 (not 87) F-350 crew cab and yes there are lot available for this engine i.e; blowers, super cobra jet heads, and much more (summitracing.com)
Old Nov 1, 2006 | 05:29 PM
cficare's Avatar
cficare
You'll never get the computers in the X to recognize the 460. You'd have to run an aftermarket engine management system, and that also means another management system just to operate the transmission. I'm going that exact approach to get a Northstar engine & 4T80E transmission in the back of my Fiero-based GT40 kit car.
I'm not saying it can't be done ... it just wouldn't make much sense. There's a ton of aftermarket hop-up goodies for the diesels. Your money would be wasted more effectively going that route. (hee hee)
Old Nov 1, 2006 | 05:32 PM
MattsExcursion
It all depends on what someone likes. I think a 460 would be different, but was just an idea. Thanks for the advice cficare
Old Nov 1, 2006 | 07:22 PM
fomoco_1's Avatar
fomoco_1
I've toyed with a swap also but am leaning toward a well built supercharged 5.4 . should'nt be a problem getting in the mid to upper 600 hp range and 700 lbft of torque. Beautiful thing is, it's not going to require massive amounts of gas unless you are running it hard. Mileage should be the same or better than what I have now 13cty/16.5 hwy. It should help out with some of the computer and fitment issues too.
yomow's Avatar
yomow
I have a 74 Lincoln that is stock w / 510 hp from the factory it is carb engine & 10.5 comp. & it is factory stock , and yes thay did use ford 460 inj. motors till 2000 .
Old Nov 2, 2006 | 07:11 AM
Casey's Avatar
Casey
1996 was the last year the Ford produced the 460 engine.
Old Nov 2, 2006 | 07:24 AM
MattsExcursion
my 97 f-350 had the 7.5L 460 in it....
fomoco_1 that sounds pretty cool!
cficare: all the 460 needs is VOLTAGE... don't need a computer to control it! I want to control it.... (its not gonna be EFI)
Old Nov 2, 2006 | 11:16 AM
X-Hibition's Avatar
X-Hibition
yomow,
A 1974 stock 460 with 10.5 to one compression ratio and 510 horsepower. It must be the only one in the world.
Amazing enough since the compression ratios were dropped by all manufacturers a few years before that. That car is a keeper.
Old Nov 2, 2006 | 01:09 PM
02XCOLLECTOR's Avatar
02XCOLLECTOR
Sounds like a great idea. I have a pair of 429 (460) Police interceptor heads.
Our T-bolt(clone) projet came with a complete motor so we never had a chance to use them.
Old Nov 2, 2006 | 01:13 PM
KrAzYKARL's Avatar
KrAzYKARL
yea they put 460s with 4v in those police interceptors. I got a f250 with a 460 2v and id bet the 4v would kick some serious but.
Old Nov 2, 2006 | 01:57 PM
02XCOLLECTOR
The 460 is underappreciated. Your MPG listed next to your vehicle made me faint. Our 64 Fairlane with a 429 Cobra-jet motor only runs a 1/4 mile at a time so we don't feel the MPG so much.
bigdawg460
Dec 9, 2003 09:56 PM
drinXsGas
Oct 22, 2002 06:55 AM
fordmaniac21
Car/truck Buying Advice
Apr 12, 2002 06:49 AM
billb
Nov 26, 2001 10:18 AM
gsmc
Oct 12, 2001 09:45 PM
