I been havin' startin' problems, so I took of my batterry and starter and had them tested and they was fine, I also put onna new relay an put everything back together and double checked my connections several times. Here is my pickle,,,I have no power! no lights, NOTHING! much less being able to start it! Please help. Thanks in advance!
Note:
Putting the topic in the title is a asset as it helps others with the same problem ....find a thread...... & helps us know what the actual topic of the thread is before we open it.
We are already here to help.
Topic:
No power anywhere
Other than Battery cable connections,
I can only suggest to check the fusible links that are wrapped up in the main harness that runs across the firewall.
Check all your ground wires and connections to ensure everything is tight. There should be one from your battery to the engine, from the engine to the frame and one from the engine to the firewall. Or some sort of combination.
On the starter relay, at the large post that hooks to the battery +, there is a smaller wire. This wire feeds the whole elec system of the truck. Follow this wire down and you should find one or more colored rubber things in the wire. These are fusible links. One of them may be burnt out.
Thanks guys. i had my wores crossed on the solenoid. Got my battery back but still have stratin problems. Put on new starter, it turned over once and then went back to clickin'.
i agree full range pon a charger then try. if you don't have one then jump it and see if it makes a diffrance. i bought a charger with my first truck and have used it on my tractors other trucks cars and various other vehicals they are woth the 60 bucks to not have to rely on a jump or going to the local store for tests
