Gear Ratio Question??
Old Oct 31, 2006 | 05:38 PM
V10nAZ's Avatar
V10nAZ
Dumb question, and partly me being lazy, but where do I find out what gear set I have in my 06 F150??
THanks
Old Oct 31, 2006 | 05:39 PM
the4by4freek's Avatar
the4by4freek
Look on your door sticker under axle code. Write it down and then come back here and use the search feature for axle gear ratio charts. It will dump you out to a thread that has them all broken down.
Old Oct 31, 2006 | 06:41 PM
hllon4whls's Avatar
hllon4whls
There used to be a tag on the rear that also told your ratio. Unless you have the HD, you should have 3.55 or 3.73's. If you have the 7 lug, 4.10s.
Old Oct 31, 2006 | 08:41 PM
Cavtrooper06's Avatar
Cavtrooper06
hllon4whls is right, if you cannot decode the door sticker just crawl under the truck and look at the metal tag bolted onto the rear diff.
