4x4 problems
Old Oct 31, 2006 | 03:39 PM
scoobydoo's Avatar
scoobydoo
4x4 problems
This is my first time posting. I have a 05 king ranch. My problem is that if it gets cold < 32 my 4x4 wont engage not even the light on the dash. There is no code on the computer so the dealer cannot figure it out. It only happens when I 300 miles away snowmibiling, when I get home its warmer so when I take back to the dealer it is working. Any ideas? I also have an edge evo now, do I have to remove when I take it in.
Thanks for the input
Old Oct 31, 2006 | 05:45 PM
the4by4freek's Avatar
the4by4freek
As for the 4x4 not engaging...it sounds like something is freezing in the system. As for your EVO... I would change it back to stock and remove it unless you have a really understanding dealer. They are going to have to plug it into thier tester and will need that port. Just make sure you return it to stock first.
Old Oct 31, 2006 | 05:48 PM
Broncoguy89's Avatar
Broncoguy89
This might help, but i'm new to these trucks so i'm not sure. My 2001 f-250 had a similar problem, and the only thing i came up with is that the hubs were vacuum actuated and the cold might affect that. But like i said not, sure. I believe the transfer case is electronically actuated, butr might use vac to pull in something else.
Old Nov 6, 2006 | 12:45 AM
fordtecher's Avatar
fordtecher
the electric motor on the back of the transfercase will freeze.
the motor may have water or moisture in it. have it replaced
Old Nov 6, 2006 | 01:10 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
my 93 Bronco would get moisture in the t-case motor and corrode until it froze up. if you're playing in weather that cold, it's not hard to believe your electric motor is litterally freezing up.
they make portable window defrosters. next time you're up there, try one of those on the motor and see if it works. or do like I did, and give it a good smack with a deadblow hammer (rubber). it only worked 3 or 4 times, but it did work
