Anybody experiencing driveshaft vibration after lift and gear change?
I've got an '04 ford f-150 with an Rancho 4" lift. I recently swapped 3.73's for 4.10's - now i've got vibration at 80 MPH.
i was referred to a good offroad shop and they told me the problem is pinion angle. Ok. i shimmed the rear end 3 degrees and yes, a lot vibration went away but i would like to get rid of the rest.
Any idea's ?
Steve
Any idea's ?
Steve
Keep in mind that due to torque the pinion will be up a couple of degrees while you're driving. If it looks dead on while everything is sitting still then it's probably out while you're driving (pinion will come up slightly) so you may need to go a few degrees more.
If you happened to seperate the slip on your shaft while doing the lift then double check the u-joints on each end are either in phase or 90 degrees out, not ****-eyed in some goofy angle or this will contribute to vibration.
you guys are going to laugh at this . . .
i first had a custom driveshaft made because of: sloppy, non-servicable u-joints and the DS was an 1/2 inch too short after the lift.
ok, the funny part . . . the tech who made my DS said he added a balancing weight because he thought i wanted to see it and NOT because it needed it. he said it balanced perfect without the weight.
My old man had a blazer with same prob, after fixing everything he and the shop could think of they put a shim (i think between the cross member and the frame) where the trans mount is. I told him that's great but there's still one problem........it's still a chevy.
Might check with the local shop and see if that's an option.
