Towing Question
Old Oct 30, 2006 | 11:34 AM
qman's Avatar
qman
Towing Question
I have a 92 F150 2wd with 300 I6 and 5 sp manual trans. I'm planning on hitching up a trailer and towing an old Ford truck about 40 miles with it. Is the truck capable of this or is this too much weight to tow/ It does have the tow hitch.
Old Oct 30, 2006 | 11:47 AM
dhag911's Avatar
dhag911
it will pull it
Old Oct 30, 2006 | 12:46 PM
Conanski's Avatar
Conanski
I have seen minivans towing tandem travel trailers.. and I'm talking Dodge Caravan's and the like, not the built on a truck chassis RWD Chev Astro or Ford Aerostar.
You can tow another vehicle with that truck... and unlike the above combinations it won't hurt your truck either.
Old Oct 30, 2006 | 03:21 PM
andym's Avatar
andym
You are well within the towing capabilities of that truck. 40 miles is no problem, it won't even break a sweat.
Old Oct 30, 2006 | 05:02 PM
qman's Avatar
qman
Thanks guys, and nice set in the avatar andym. Nothing beats genuine parts, and that's a nice set of parts.
Old Oct 30, 2006 | 05:23 PM
Steina's Avatar
Steina
CO River Rat
qman -
Got brakes on that trailer?
Steve
Old Oct 30, 2006 | 05:42 PM
andym's Avatar
andym
lol... I'll tell my girlfriend you said so.
Old Oct 30, 2006 | 06:00 PM
mantta's Avatar
mantta
I just got back from towing a Model "A" Ford from Norfolk, VA to Michigan's Upper Peninsula. Trailer plus car, about 4500 pounds plus in the truck box I had an extra Model "A" engine, an engine stand, a engine lift, an oxy acetelyne rig, a refrigerant recovery unit and three large boxes of Model "A" parts. My truck is an 88 F-150 with a 4.9, AOD. It worked pretty hard on the hills in West Virginia and I averaged around 10.8 mpg (I normally get 19-20 mpg hwy). In the 1330 mile trip I had no problems. I stayed out of overdrive for the transmissions sake. You should not have any problems with 40 miles.
Old Oct 30, 2006 | 06:50 PM
Bulldog66's Avatar
Bulldog66
I pulled a 17' Boat for several years with an I6 / 5sp F150. Ford rode that set up for along time.
You're fine.
Old Oct 31, 2006 | 10:24 AM
qman's Avatar
qman
No brakes.
Old Oct 31, 2006 | 10:30 AM
McLeod's Avatar
McLeod
You sure could tow with your truck, but without brakes on the trailer (if I understand correctly that you are towing another truck) you should think twice.
Your 1/2 ton will not safely be able to slow down that much weight on flat ground let alone hilly terrain.
You should also check YOUR state law to find out when they REQUIRE brakes on trailers.
BE SAFE!
Old Oct 31, 2006 | 10:41 AM
Steina's Avatar
Steina
CO River Rat
qman -
CO requires brakes if the trailer's gross weight is over 3000#; you might want to find another trailer, for your safety and that of others on the road.
Steve
