Drivers side automatic door lock not working
Old Oct 30, 2006 | 11:03 AM
dcwhipple's Avatar
dcwhipple
Background…I just bought a 2000 7.3L F350 that needs a little work. I’m a shad tree mechanic who thinks that he can do more than he actually can . Found your community and have really enjoyed what I’ve read so far.<O</O
Issue #12 of many: Drivers side automatic door lock not working.
I pulled the drivers door apart, pulled the actuator (? little plastic black box with the motor and gears in it?) off and drilled out the rivets. When I separate the motor from the rest of the gears, it spins when current is passed through it. When I introduce the first gear to the work stream, the motor does not have enough umphhh to spin it.
Questions:
1) Do I need to check the current going to the motor or can I assume that if the passenger lock is working, the “system” overall is passing enough power?
2) Assuming I need to replace the motor (or whole actuator), is there an on-line source that I go to find out the model number and, more importantly, what years/models used the same motor/actuator?
3) What are the sources you guys use for new/used parts? Reason I ask…I tried a junkyard for a driver side mirror and they wanted $100+tax for a used one. I found a new (non-OEM) on the web for $110 total. Wassup with that?
4) Assuming I’m not getting enough juice, what’s the next step?
</O
<OThanks!</O
<ODan </O
Old Oct 30, 2006 | 11:16 AM
BowTieHatr's Avatar
BowTieHatr
the actuator is just weak. i think they are like 50 bucks at the dealer.
Old Oct 30, 2006 | 04:31 PM
empiretc's Avatar
empiretc
it is just so much easier to add aftermarket actuators and leave the oem ones there. i put the new ones in an easy place to get at so if i never need to replace one it will be a piece if cake. I paid ~$20 for a set of 4.
Old Oct 30, 2006 | 05:23 PM
SpringerPop's Avatar
SpringerPop
dcwhipple,
See: https://www.ford-trucks.com/forums/4...light=actuator
You have to go deeper. Inside the motor. Jumper the varistor with a piece of aluminum foil.
A piece of cake! Cheap, too!
Pop
Old Oct 30, 2006 | 08:38 PM
dcwhipple's Avatar
dcwhipple
SWEET! Thanks Pop!
Old Oct 31, 2006 | 02:36 AM
empiretc's Avatar
empiretc
Pop, i read that thread many a times when I was having troubles with my door locks. Then I thought about the time it would take and the chances of me messing up (pretty high odds), and thats why I went the other route.
Old Oct 31, 2006 | 09:56 AM
SpringerPop
The actual fix involves some pretty tiny moves, and you sure can't be ham-fisted when retracting the motor brushes to replace the motor's end piece. A small dental pick works well.
The brushes are about twice the size of the head of a pin, to give some relative size to this discussion.
But if you have ever had the patience to work on tiny projects, this is a fix that definitely works well, and is cost-effective, too!
Pop
Old Oct 31, 2006 | 08:19 PM
Duane99's Avatar
Duane99
All four of mine went out so I did the tin foil fix, didnt take long at all and was very easy to do and havent had any problem since. Mine was doing the same thing, they seemed weak and now have all the pwr back to them
