Sponsored by: Auxito
Hazard lights not working
Old Oct 30, 2006 | 07:13 AM
gfreek's Avatar
gfreek
Hazard lights, (4 way flashers), quit working. Usually I replace with a new relay, & it takes care of it. This time it still doesn't work. It clicks once then stops. This has been an on going problem. Replaced the multifunction switch afew years ago. Turn signals work OK, except sometimes only one side works and the other is real dim and seems to dim the lights when it tries to flash. 5 minutes later all is OK with turnsignals. Traced wiring in frame, found nothing. Anyone with any ideas or had a similar problem ??
Old Oct 30, 2006 | 01:58 PM
LxMan1's Avatar
LxMan1
It's either a bad bulb socket or the flasher switch is bad again.
Old Oct 30, 2006 | 09:57 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
My 4-ways have never worked in the 15 months I've had my truck....
Old Oct 31, 2006 | 04:59 AM
gfreek's Avatar
gfreek
I'll try a new turn signal/multifunction switch and let you know.
98powerstang
Dec 5, 2012 08:41 PM
03-6L-X
Nov 4, 2009 03:57 PM
bobpearson90278
Feb 23, 2007 01:17 PM
littleneddy
1978 - 1996 Big Bronco
Oct 8, 2004 06:12 PM
nucleartruck
Electrical Systems/Wiring
Apr 25, 2004 08:48 PM
