Sponsored by: Auxito
Wind noise from 97 extended...
Old Oct 29, 2006 | 09:15 AM
P95Loser's Avatar
P95Loser
I have a 97 f-150 extended cab 3rd door... when going about 60 miles an hour or faster, there is a wind noise comin from the passenger side where the 3rd door is. Doors are shut good and window is up, any suggestions on how to help this?
Old Oct 29, 2006 | 09:27 AM
RangerPilot's Avatar
RangerPilot
A friend of mine has a '99 which had this problem. Part of the weatherstripping between the passenger side front and rear doors had come unstuck.
Just a thought.
Old Oct 30, 2006 | 07:35 PM
Bruin52's Avatar
Bruin52
My '99 ext. cab does it on the front of the drivers door. The wind caught the door when my buddy was getting out of it during a hurricane and bent the upper door hinge a little bit. Hardly noticeable visually but it doesn't allow a good seal.
Old Oct 30, 2006 | 08:27 PM
AzBlueWolf's Avatar
AzBlueWolf
there should be a vertical strip of weatherstrip on the rear door...if its out of place or missing there will be wind noise
Old Oct 31, 2006 | 07:11 AM
mikieday's Avatar
mikieday
i have a 2001 ext cab and i was getting wind noise from the passenger door.
my buddy who works for ford said he would fix it just like they do on the line if the body line doesnt match up ...he braced the bottom of the door with a block of wood in the open position and grabed the top of the door and pulled on it hard towards the inside..problem fixed....i was a bit taken aback with this but it worked...
mikie
