56 Towing capacity
Old Oct 17, 2002 | 11:59 PM
blitzkraig56's Avatar
blitzkraig56
56 Towing capacity
So I've decided to do a frameup rodstoration of my truck. In the final form I wanted to have a hidden tow hitch reciever behind the license plate (which will be in the center of the rollpan). So since I'm starting off with the frame, do I need to reinforce it in any areas like more crossmembers or an X member? And I just realized, I have a Mustang gas tank setup in the rear as well. Will that cause complications?
Craig
Old Oct 23, 2002 | 12:27 AM
blitzkraig56
56 Towing capacity
helloo? anybody out there?
Old Oct 23, 2002 | 06:42 AM
fatfenders's Avatar
fatfenders
56 Towing capacity
Craig
You might have to pioneer this one
How far forward is the edge of the Mustang tank? I think is is going to severely limit the GVW rating on this hitch.
'fenders
Old Oct 24, 2002 | 10:41 PM
blitzkraig56
56 Towing capacity
Ok, so I've been thinking about it and I may have come up with an idea but I wanted to see if it makes sense to anyone else first. I've added a picture at the bottom. So the aftermarket trailer hitch frame will weld in and take place as a rear crossmember (green lines). And since that probably would bend outward and suck the frame in when I tow something heavy, I'll weld in some square steel tubing where the red lines are, so the outward pulling force will go to the reinforcements which will pull on the sides of the frame where the second crossmember is. I think it makes sense, but maybe not. BTW the circle is the fuel filling port on the mustang tank.
Craig
http://www.geocities.com/norcal_f100/hitch.jpg
Old Oct 24, 2002 | 11:57 PM
blitzkraig56
56 Towing capacity
[updated:LAST EDITED ON 25-Oct-02 AT 01:00 AM (EST)]bleah, stupid geocities pictures never work....nevermind
if you're really that curious the address is geocities.com/norcal_f100/hitch.jpg
Old Oct 25, 2002 | 06:13 AM
fatfenders's Avatar
fatfenders
56 Towing capacity
Craig
Not sure what you are intending to pull but I think your plan has a good chance of working well for light loads. A good crossmember closer to the rear would be ideal in my opinion but I suppose that's about where your Mustang tank must be.
'fenders
Old Oct 25, 2002 | 09:50 AM
Kenny's Avatar
Kenny
56 Towing capacity
bzerk56
Dec 27, 2016 09:17 PM
vanspeed
Sep 15, 2016 07:43 PM
mbutts
Apr 18, 2016 06:57 PM
steve(ill)
1997 - 2003 F150
Jan 20, 2016 06:16 PM
Kootenay56
87
Nov 8, 2009 09:04 PM
