Tranny Trouble
Old Oct 29, 2006 | 09:34 PM
bigos71's Avatar
bigos71
Tranny Trouble
I have a 1992 Ford F150 Tk. The auto-transmission will not work in forward, but reverse works fine. If i keep it in drive it will then work. Reverse is fine. Transmission does not slip when on the highway. One time today putting it into drive worked fine and reverse didn't work. Could it be the torgue converter acting up? Thanks
Old Oct 30, 2006 | 02:28 AM
kbolk's Avatar
kbolk
Hi. Im haveing the same problem with my 92 f150. But my tranny will for a little while but it takes about ten seconds before it will start to move. after a while of driving though,{10 minutes{,. Once i come to a stop and try going again it wont move . sure the engine revs up and is working good when gas applied. I have to unhook battery for a minute or two then it works again but only for a bit of time.reverse always works good, can even spin the tires in reverse. If any thing my tranny fluid is to high
Old Oct 30, 2006 | 04:45 AM
bigos71's Avatar
bigos71
Thanks for replying. My transmission once it engages works fine. Has good power , no slippage.
Old Oct 30, 2006 | 08:19 AM
subford's Avatar
subford
The TPS sensor can cause the transmission to do this as if the EEC thinks the engine is at idle it will not increase the transmission oil pressure to apply the clutches. Also the TR sensor can give some problems along these lines.
TPS - Throttle Position Sensor
EEC - Electronic Engine Control
TR - Transmission Range Sensor
Old Oct 30, 2006 | 09:02 PM
kbolk's Avatar
kbolk
trottle position sensor
Hi, I was just wondering how would the tps make the tranny not go into gear? And if its a easy thing to change.
Old Oct 30, 2006 | 09:40 PM
EPNCSU2006's Avatar
EPNCSU2006
I was thinking the same thing...
Old Oct 31, 2006 | 06:56 AM
subford's Avatar
subford
Before the PCM when a transmission would take a long time to go into gear or not at all at idle and you had to rev it up to get into gear the problem was the seals were bad or the pump/filter was not providing the oil pressure.
This of course was cause by low oil pressure before the PCM.
Now with the PCM you can get the same thing if the PCM does not think you are in gear (TR sensor) or the throttle is closed (TPS sensor) and the PCM will leave the oil pressure in the transmission low causing the same thing as above. Also a bad PCM or wiring would make this happen too.
Not saying this is the problem but it is about the only thing that can do it without going inside the transmission and I can not think of anything inside that would have these symptoms other than bad filter or low oil level and then run fine.
One other possibility is the shift linkage is out of adjustment at the transmission.
Old Oct 31, 2006 | 07:27 AM
EPNCSU2006's Avatar
EPNCSU2006
so what you're saying is that an electronic automatic won't go into gear unless you press the throttle....kinda like doing neutral drops then? That doesn't make sense to me. What if the screen is clogged like what would happen on a non-electronic automatic?
Old Oct 31, 2006 | 07:55 AM
subford's Avatar
subford
Its not that it is not going into gear but the oil apply pressure is low and the clutches are slipping.
If the screen is clogged you would never ever get the pressure up to run OK.
Old Oct 31, 2006 | 12:07 PM
EPNCSU2006's Avatar
EPNCSU2006
so what does that have to do with throttle position? Shouldn't it go into gear whether the throttle is pressed or not?
Old Oct 31, 2006 | 12:58 PM
kbolk's Avatar
kbolk
one guy suggested i take off my tranny line to the rad and see if the pump is working. if it is the pump is that an easy thing to change with out removing the trannt. Also if the electronics are fcuked up would that cause my pump not to work ?
Old Oct 31, 2006 | 04:42 PM
subford's Avatar
subford
The TPS tells the PCM how much pressure to use in the transmission. While at idle very low pressure and low heat generated.
Old Oct 31, 2006 | 04:47 PM
subford's Avatar
subford
You have to remove the engine or transmission (one or the other) to replace the pump. AS I have said above the PCM controls the oil pressure leaving the oil pump in the transmission.
Old Oct 31, 2006 | 04:53 PM
kbolk's Avatar
kbolk
So if the tps is faulty, what do u do to repair it?
Old Oct 31, 2006 | 07:41 PM
subford's Avatar
subford
You would have to replace it. I am not saying that is what is wrong, it is just a possibility and it has fixed other posters transmission problems.
Could be other things inside the transmission like sticking valves in the valve body, worn pump and bad solenoids.
