Dash and tail lights out
Old Oct 29, 2006 | 09:15 PM
93tankus's Avatar
93tankus
Hello All,
I was driving my '93 F150 this evening and the dash lights and the tail lights went out. I still retained my headlights, brake lights, hazards (in rear), and turn indicators (in rear). I checked fuses and all seemed to be well. Any help/advice would be much appreciated!!
Thanks in advance!!
Old Oct 29, 2006 | 09:28 PM
Franklin2's Avatar
Franklin2
I am guessing your front marker lights are out too. If all the fuses are good, then it sounds like the tan/white wire going to the headlight switch may have burnt in two. It happens once in awhile.
What you can do is pull the headlight switch out, and with it plugged in, probe the tan/white wire to see if it has voltage. If it doesn't, follow it back and see if there are any problems with it. This wire comes directly from the fuse panel.
If you have voltage on the tan/white, unplug the plug and look at it to see if it's melted. If it looks ok, your headlight switch may be bad. The tan/white feeds the marker light contact in the headlight switch, and also feeds the dash dimmer part of the switch internally. So if you lose the tan/white feed, you will lose the dashlights also.
Old Oct 29, 2006 | 09:47 PM
93tankus's Avatar
93tankus
Thanks Franklin!
A bit of a stupid question (newbie...), but when you refer to the "headlight switch", you're not referring to the headlight **** you pull out to turn your lights on, are you? If not, where exactly is the headlight switch?
Thanks again!!
Old Oct 30, 2006 | 05:54 PM
Franklin2's Avatar
Franklin2
Yes, the headlight ****. I am not sure what type of switch your year has, but some had a little button on the switch you have to push to release the **** and shaft assembly. Others, you just pull the **** off.
If you feel a little button on the part of the switch behind the dash, opposite of the wiring side of the switch, then go out and take the battery cable off, pull the headlight switch **** all the way out, reach back and push on the button, and then pull the **** and shaft all the way out.
You can then re-insert the ****, turn the switch off, hook the battery up temp, and then do some testing with a meter.
Old Oct 30, 2006 | 06:06 PM
93tankus's Avatar
93tankus
Cool. Thanks Franklin. I actually went ahead and took the dash facade off, unscrewed the headlight switch, and unplugged the switch. As I was doing this, the dash/tail lights were flickering on and off. After I unplugged the switch, there appeared to be some small heat damage to one prongs and it's area of connection. I'm hoping this is the culprit. I'm off to the auto parts store to see (hopefully) if they have a replacement headlight switch. Keep ya posted. Thanks again for the help!
Old Oct 30, 2006 | 08:02 PM
93tankus's Avatar
93tankus
Indeed, the new headlight switch did the trick! Thanks a ton for the help and advice!
jerrysrios
Electrical Systems/Wiring
91
Feb 18, 2025 03:12 PM
wence5
Jun 13, 2022 04:55 PM
islanddave
16
Jul 23, 2007 11:34 PM
jwcorder
1983 - 2012 Ranger & B-Series
Apr 26, 2006 05:41 PM
killerklown
1978 - 1996 Big Bronco
Apr 11, 2004 11:10 AM
