I know I need to replace my injectors and here is my question:
does it make any sense to put higher pressure injectors in my truck or just stay with the stock ones? and if so what pressure? (i dont even know the stock pressure)
I will agree stay with stock unless you have made some other serious changes such as adding a supercharger, stroked the motor, and/or serious tuning changes with nitrous added.
The reason I bothered to post is to add, the injectors are not higher preasure, the bigger injectors are higher flow rates. I know they read things like 19lbs but your not reading the entire thing closely that is actually 19lbs/hr it's a amount per time figure not a preasure figure.
