1966 - 1977 Early Broncos
wheres my neutral S. Switch??
Old Oct 28, 2006 | 12:42 PM
v8xploder's Avatar
v8xploder
On my 69' I cant find the neutral safety swich....I checked the clutch pedal and the side of the trans (3SPeed) I cant seem to find it? Any one know???
Old Oct 28, 2006 | 08:27 PM
McLeod's Avatar
McLeod
Did they have them back in '69?
My '69 didn't have one.
Old Oct 28, 2006 | 09:38 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
They did not use a neutral saftey switch in 1969.
Tim
Old Oct 28, 2006 | 11:29 PM
RCrawler's Avatar
RCrawler
Neutral safety switch was used only on the automatics when they were offered in 73 and up.
There is no clutch start switch on the manual trans equipped.
Did you figure out your starting problem?
Jason
Old Oct 29, 2006 | 10:19 AM
v8xploder's Avatar
v8xploder
No, I havnt found the problem yet... I still cant get 12V to the S terminal in the crank position. I did find a Purple wire that is in the harness that goes to the ign switch, It has an "slide on" style fitting and it doesnt seem to go anywhere...
Old Oct 30, 2006 | 12:05 AM
RCrawler's Avatar
RCrawler
The purple wire goes to the brake warning light. If you jump the yellow wire to the red/ blue stripe wire at the ignition switch, does it crank? Do you have 12V at the yellow wire?
Jason
Old Nov 3, 2006 | 04:24 PM
68 351 bronc's Avatar
68 351 bronc
Before I would spend anymore time messing with the old harness I would just run a new wire from the hot side of the starter solinoid to the ignition switch. Then from the ignition switch back to the starter solinoid. Or do the same and get a spring loaded switch to mount in the dash and forgo wiring into the keyed ignition for the starter. If your keyed ignition switch is bad you can buy one from NAPA or any good auto parts store.
Apa
Oct 20, 2012 08:31 AM
madsonp
Nov 16, 2010 05:55 PM
serealport
13
Feb 16, 2008 03:32 PM
mauicruza
May 1, 2006 09:28 AM
dusty's77
Jan 16, 2005 07:13 PM
