Does the EBPV affect EGT?
Old Oct 27, 2006 | 02:16 PM
GoCamping's Avatar
GoCamping
Yet another EBPV question...
Recently installed my Walker BTM so I've been watching my EGTs since. First time I drove it, was about 65deg out in the afternoon. Went for a test drive after the install. Noticed that temps were lower from what I remembered, and didn't rise as fast (esp WOT).
Next time I drove it, it was ~40deg out and 10pm - truck had been sitting outside all day instead of in the "warm" garage. Temps seemed higher, but then started to behave after halfway home (30min drive, mostly interstate). Temps didn't seem to be an issue that morning (truck had been in the garage then).
Am I imagining things? All I could think was that the EPBV was restricting flow, but ??. I might have to do some cleaning per that previous post...
Old Oct 27, 2006 | 02:20 PM
Fire Rooster's Avatar
Fire Rooster
Yes you are seeing the effects of the EBPV being closed in order to warm up the truck.. Once it reaches normal operating temps you shouyld see the EGT's drop.
Old Oct 27, 2006 | 02:21 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
well, the EBPV is either open or closed, yes it can create a major increase in EGT, since it's restricting almost ALL of the flow out of the turbocharger. with the BTM on, you could clearly hear the hissing noise under the truck, even with all windows up. it's loud once you open the exhaust system up.
Old Oct 27, 2006 | 06:17 PM
GoCamping's Avatar
GoCamping
Red face
Okay thanks - I tend to get paranoid. I'll have to listen closer for the hissing, I guess it's really noticeable?
Old Oct 27, 2006 | 06:20 PM
PowerstrokeJunkie
When i had my truck straight piped and still had an EBPV, i could stand directly behind the truck when it kicked on raised idle (factory, not my chip), and when the EBPV closed, i honestly couldn't hear the engine over the roar of the EBPV at around 900-1000 rpm.
i deleted the EBPV from my truck, i haven't heard it since then
Bigtruc
20
Dec 26, 2013 10:24 AM
Justin03PSD
23
Apr 15, 2013 09:43 AM
ScaldedDog
Sep 29, 2011 01:27 PM
dmueller71
Jan 23, 2007 12:25 PM
pullinair
Oct 23, 2006 05:57 PM
